Read my Plugs
Old Aug 21, 2007 | 09:17 AM
devnull's Avatar
Default Read my Plugs
So I went to do a compression test, just to be sure everything is okay. Look at my spark plugs. I know something isn't right but I can't remember what it means. Either I am not using a high enough octane, though I'm using 91, or my plugs are too hot or cold.
Old Aug 21, 2007 | 10:45 AM
mmuller's Avatar
Mad Scientist
Default Re: Read my Plugs (devnull)
been using any fuel additives?
Old Aug 21, 2007 | 11:02 AM
Flashmn's Avatar
Default Re: Read my Plugs (mmuller)
they look normal to me.
Old Aug 21, 2007 | 11:18 AM
Bakeoff's Avatar
A) get rid of the split fires. I've never seen them happy long term on a honda. The multiple spark is great, but it can also lead to a weaker spark.
B) How'd the compression test go? Looks like you might be burning a little something extra...
C)Is that oil on the threads?
Old Aug 21, 2007 | 12:19 PM
devnull's Avatar
a) Those are NGK's. These are pulled from a 91 318is, these are the stock plugs.
b) Compression test went fine. 195 degrees temp, #1) 212, #2)220, #3)215, #4)225
3) The "stuff" on the threads is a copper based anti-seize.
Old Aug 21, 2007 | 09:31 PM
gourley's Avatar
Default Re: (devnull)
Plugs look good, maybe a tad lean but look good to me.
Old Aug 22, 2007 | 04:10 AM
Rd91SiB18ls's Avatar
your plug look normal they should be light gray or tan in color, normal burn
Old Aug 22, 2007 | 10:19 AM
mmuller's Avatar
Mad Scientist
Default Re: Read my Plugs (Rd91SiB18ls)
those plugs are not burning clean
jtrig
Honda Civic (2001 - 2005)
Jun 2, 2015 03:55 PM
h22nate
Apr 20, 2010 05:57 PM
sneakychaos
Nov 8, 2008 04:47 PM
Westrock2000
Jan 26, 2003 09:58 AM
PressurizedSi
Nov 29, 2002 03:48 AM
