High Idol
Old Aug 19, 2007 | 05:29 PM
Lsgsr94's Avatar
Default High Idle
As soon is i start my car the idle shoots straight up to 4200rpm and stays.I belive its the air idle control because the black plastic housing on it is cracked clean through.Im gonna replace that anyway but i was wondering could it be anything else the map or any other sensor.I have a B18b!
Modified by Lsgsr94 at 3:27 PM 8/20/2007
Old Aug 20, 2007 | 05:22 PM
slowcivic2k's Avatar
Default Re: High Idle (Lsgsr94)
If the housing is cracked, remove it and plug the two holes on the back of the manifold where it gaskets to, and turn it over. If it idles really low after blocking that, that IACV sure sounds like your culprit.
Old Aug 21, 2007 | 03:44 PM
Lsgsr94's Avatar
Default Re: High Idle (slowcivic2k)
I tried it today it didnt work but i checked the oil and it was white so now im thinkin head gasket or some kind of coolant issue!
1250b18c5
21
Oct 9, 2011 08:31 PM
twentyhurtz
Jan 16, 2009 08:30 AM
loudassVTEC
Oct 5, 2005 10:40 PM
Import RP
May 31, 2002 06:37 AM
