WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE???????????
Old Aug 19, 2007 | 05:20 PM
integracura's Avatar
Default WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE???????????
Just wanted to know which 9006 low beam bulbs were the best, i have used nokya bulbs with stage 2 wiring harness and it lasted me two years, but now the bulbs and wires are burned and messed up, so i just got regular oem quality wiring harness and now just have to buy bulbs but not quite sure which ones to get. Help me decide.
Old Aug 19, 2007 | 09:34 PM
blinx9900's Avatar
Default Re: WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE??????????? (integracura)
all suck, the best are phillips x-treme 80%+ check out my wright up!
http://www.ek9.org/forum/showthread.php?t=353
Old Aug 20, 2007 | 07:41 AM
Padawan's Avatar
Darth ModerVader
Default Re: WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE??????????? (blinx9900)
I would suggest a pair of 9012 HIR bulbs.
Old Aug 20, 2007 | 01:08 PM
blinx9900's Avatar
Default Re: WHICH BULBS ARE THE BEST BASED ON PERSONAL EXPERIENCE??????????? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest a pair of 9012 HIR bulbs. </TD></TR></TABLE>
just read up on them, very intresting, i wonder how they compare to the phillips x-treme, i have 4300k hid's in my other civic and i like the philips x-treme more.
Old Aug 20, 2007 | 01:27 PM
Padawan's Avatar
Darth ModerVader
They should perform significantly better than the X-treme Powers, but keep in mind that it's not a direct comparison since the X-treme Powers are only currently available in H7 and H4 applications, not the 9006 being discussed here.
Old Aug 20, 2007 | 01:31 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">They should perform significantly better than the X-treme Powers, but keep in mind that it's not a direct comparison since the X-treme Powers are only currently available in H7 and H4 applications, not the 9006 being discussed here. </TD></TR></TABLE>
perhaps im being retarted but i though the 9006 was a crossrefrence to the h4, i must be thinking of some other 900x?
edit: yeah i was thinking of 9003 sorry.
Old Aug 22, 2007 | 07:54 AM
where can i buy philip xtemes?? the 9012 are to expensive, theyre $50 for a pair.
Old Aug 22, 2007 | 10:11 AM
Padawan's Avatar
Darth ModerVader
Default Re: (integracura)
Philips X-treme is not available in 9006, and the pricing for those bulbs ranges from $40-$50 anyway.
$50 per pair is not much to pay for greatly improved lighting performance.
Old Aug 23, 2007 | 04:21 AM
i heard you have to do some modifications to the HIR bulbs, what is that?? and i went to advance auto parts today and they had Sylvania Ultra Night Vision bulbs for $50 and they had some Hella Bulbs for $45, they both were 12v and 55W and that the same as oem, so should they be good??
Old Aug 23, 2007 | 08:53 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">i heard you have to do some modifications to the HIR bulbs, what is that?</TD></TR></TABLE>
http://hirheadlights.com/FAQs.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">and i went to advance auto parts today and they had Sylvania Ultra Night Vision bulbs for $50 and they had some Hella Bulbs for $45, they both were 12v and 55W and that the same as oem, so should they be good??</TD></TR></TABLE>
Neither will perform nearly as well as the HIR, so if you're going to be spending the money, I'd suggest picking up a pair of 9012 HIR's instead.
Old Aug 23, 2007 | 12:29 PM
slomofo's Avatar
GDD Member
HIDs are cheap, why not just upgrade or keep them stock?
vtec2K9
Lighting
Jul 3, 2008 08:44 PM
phaders
Nov 4, 2004 08:04 PM
hometheaterman
Oct 7, 2004 12:41 AM
mrcrimane
May 5, 2003 11:41 AM
