Chip burning???
Old Aug 20, 2007 | 01:36 PM
crashzerothree's Avatar
Default Chip burning???
I am trying to use flash & burn to make a chip, i put the buffer address to 8000 and push program chip it says error:source start and end addresses are invalid. It wont let me do anything, not even erase the chip, What does that mean?? im new to the chip burning scene, but i just need to burn a stock GSR bin, i have crome, a burner, a 27sf512 chip, and the Burn1 program
Old Aug 20, 2007 | 08:27 PM
.dave's Avatar
i HAS questions ?
Default Re: Chip burning??? (crashzerothree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashzerothree &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to use flash & burn to make a chip, i put the buffer address to 8000 and push program chip it says error:source start and end addresses are invalid. It wont let me do anything, not even erase the chip, What does that mean?? im new to the chip burning scene, but i just need to burn a stock GSR bin, i have crome, a burner, a 27sf512 chip, and the Burn1 program</TD></TR></TABLE>
You'll most likely have better luck searching/asking for help over on PGMFI.org.
Old Aug 21, 2007 | 07:41 AM
Relic1's Avatar
buffer address remains 0000-7FFF, chip addressing changes to 8000-FFFF
UNLESS you're trying to burn a 64k bin. then leave the settings at 0000-FFFF for both.
OR you have a two-timer then you use both the upper and lower memory locations and switch between the two.
you have a burner?... you mean the Burn1 correct? if you're trying to use a different burner with the Burn1 software it will not work.
Honda4life777
Engine Management and Tuning
Jul 11, 2009 09:39 PM
92turbob16
Jun 16, 2009 08:16 AM
Powered By Garrett
11
Jul 4, 2008 08:44 AM
jedsus
Apr 25, 2008 08:36 PM
the.hamburglar
Mar 20, 2006 03:28 PM
