!!!HELP...ENGINE BOGGING @ 3500RPM
Old Aug 30, 2007 | 09:13 AM
91ef8's Avatar
Default !!!HELP...ENGINE BOGGING @ 3500RPM
I have stock 91 crx...replaced piston rings and put engine back together...was running perfect before taking apart...engine idles perfect and now when i rev the engine it wont rev past 3500 rpms... it will bog out and bounce off the 3500 rpm mark and wont rev any higher...can someone out there help me figure this thing out...
what I have done:
-ive checked and rechecked the timing
-replaced the dizzy, cap and rotor
-ecu not throwing any codes at all (ecu is stock, same as engine)
need some help im stumped...
Old Aug 30, 2007 | 12:22 PM
Jeanious's Avatar
check all your grounds
Old Aug 30, 2007 | 12:59 PM
91ef8's Avatar
Default Re: (Jeanious)
hmm..didnt think of that..when i get to the house today imma check them out and re-ground them
Old Aug 30, 2007 | 04:37 PM
roadracer321's Avatar
Its your Kuneutson valve. Engines with camshafts have them. The number one sign of Kuhneutson failure is reduced bore on your engine block. Just a thought...
Old Aug 31, 2007 | 09:37 AM
91ef8's Avatar
Default Re: (roadracer321)
so if that is the problem..would i have to either bore out the block or just go out and get a new block?
Old Aug 31, 2007 | 01:29 PM
BIGTUNA's Avatar
Default Re: (91ef8)
SCARY
Old Sep 1, 2007 | 05:57 AM
I was f'ing with you... There is no such thing as that valve, and you cant reduce bore size... Check your fuel lines and **** though. Check everything that you touched when you did that job. Could be numberous things.
Darrell Woods
19
Aug 23, 2015 01:37 AM
91ef8
17
Sep 7, 2007 03:18 PM
91ef8
Sep 4, 2007 05:20 AM
91ef8
Aug 30, 2007 12:09 PM
urtz
May 27, 2007 12:41 AM
