Is it safe/ok to sandblast a head??
Old Aug 22, 2007 | 08:44 AM
WishinItWas's Avatar
Default Is it safe/ok to sandblast a head??
Im in the process of building a B18a1 head and couldnt find any input on sandblasting the bare head. any one have experence with this? what grade (correct term?) of sand/shot to use or is it stupid to risk not being able to clean the head well enough after?
thanks in advance
Old Aug 22, 2007 | 09:54 AM
tony413's Avatar
Default Re: Is it safe/ok to sandblast a head?? (WishinItWas)
i've seen machine shops do it but what grade abresive i dont know of they used it to clean the ports anyways take a look at my thread
Old Aug 22, 2007 | 01:43 PM
Padawan's Avatar
Darth ModerVader
I wouldn't use abrasive media on it. Instead, have it hot-tanked.
Old Aug 22, 2007 | 01:50 PM
TooManyTickets's Avatar
Default Re: Is it safe/ok to sandblast a head?? (Padawan)
ive done it to 4 heads two of them were for a chevy 350 the others were for a Ford small block.. the chevy ones were just dirty as all heck and in the process of cleaning them off we discovered a crack in one of them so that project was junked.
The ford heads however were a nice aluminum bit and went into the glass beader for cleaning... <--- that is not really recomended unless u plan on completly rebuilding the head... not to mention you will be spending litterally hours getting the leftover glass out of there because if any of that gets into a running engine it will not be preaty.
i spent a good amount of time blasting the thing with air.. then we hot tanked it and then when we though we were done we took a preasure washer to them.
Old Aug 22, 2007 | 02:58 PM
methos713's Avatar
Default Re: Is it safe/ok to sandblast a head?? (TooManyTickets)
took my z6 head to the machine shop and had it sandblasted and hot tanked. I haven't installed it, so I don't know the effects yet...but it sure did come out clean.
sanman000719
Jan 22, 2011 04:59 PM
RACEPAK
Jul 22, 2007 07:08 AM
95hbMatt
Jun 12, 2002 10:03 AM
builthatch
May 7, 2002 04:19 PM
