NEED HELP! OBD 1 with codes
Old Aug 23, 2007 | 04:18 PM
lilmex's Avatar
Default NEED HELP! OBD 1 with codes
6 and 24 ( I think). Please.
Old Aug 23, 2007 | 06:11 PM
lilmex's Avatar
Default Re: NEED HELP! OBD 1 with codes (lilmex)
I's 6 and 15 not 24. I know what 6 is now but number 15 is "Ignition output signal". Is that my ignitor going bad? My car turns on but it revs up and down. Then it wants to die unless I give it some gas. Please help!
Old Aug 23, 2007 | 07:10 PM
slowcivic2k's Avatar
Have you spliced the distributor for a swap? check the wires inside under the rotor cap for corrosion or poor connectivity. Normally a code (15) like that will have a mid to high load (high throttle) misfire at all RPM.
Old Aug 24, 2007 | 05:11 AM
lilmex's Avatar
Default Re: NEED HELP! OBD 1 with codes (slowcivic2k)
No wires were spliced. I checked to see if they were connected right and everything was correct. ANYMORE THINGS TO CECK?!? Please help.
Old Aug 24, 2007 | 11:26 AM
lilmex's Avatar
Help!
EF4lyf3
Jul 10, 2010 05:28 PM
Jap_Spec_Imports
Jan 24, 2009 07:14 PM
b18c1del
May 24, 2007 08:21 AM
SoOHiGH
Jun 8, 2005 04:24 PM
SMZ GSR
Jun 7, 2005 05:40 PM
