b17a rods
Old Aug 21, 2007 | 07:38 AM
amadriga's Avatar
Default b17a rods
Is there a online store to buy some OEM b17a rods?
I have a crank, but I can't find them.
Thanks!
Old Aug 21, 2007 | 06:08 PM
doood's Avatar
been there done that
Default Re: b17a rods (amadriga)
http://www.sonsacuraparts.com
part# 13210-P61-A00
Old Aug 22, 2007 | 01:49 PM
amadriga's Avatar
Default Re: b17a rods (doood)
Thanks, I will ask.
Old Apr 19, 2016 | 10:45 PM
clomonolo's Avatar
Thanks!
Did you find them? I need one and having a hard time finding then
Old Apr 22, 2016 | 12:35 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
You may luck out if you call crower, they might make another set of them if you ask nicely. Im pretty sure they only made a small run of them a few years ago and didnt produce any more.
Also, have you made a Want to Buy thread on G2IC?
Old Apr 22, 2016 | 01:49 PM
clomonolo's Avatar
They want 350 a rod and i could get the crower strokerkit for that but block/crank only have 80 miles on em. Some dumbass didn't torque the bolts to spec or used the same bolts not sure but i bent one rod. If i getone rod if a different style is that going to throw off the weight/balance, will there be knocking or miss fires. And i don'tk ow nothing bout g2ic but I'll check it out.
Old Apr 22, 2016 | 07:18 PM
Ugh. That sucks. On the cylinder that bent the rod, how does the crank journal look? Have a machine shop make sure the crank isnt warped. If you replace one rod, and dont get a whole new set, I would get a machine shop to balance everything. Even if they are all stock p61 rods.
I ended up selling my stock crank and rods to a guy in France in 2011 for about 450 not including shipping if that tells you anything about how hard they are to find.
forums.g2ic.com
Also clean out your inbox. I tried to PM you, but it was full.
f20b jones
12
Dec 23, 2010 09:12 PM
lunatics209
Jun 12, 2008 01:38 AM
paulzy
Dec 22, 2001 10:41 AM
