over heating problem
Old Aug 18, 2007 | 05:43 PM
ghettochild's Avatar
Default over heating problem
its a fresh motor 0 miles, motor idles fine and then about 10 to 15 mins the overflow tank starts over flowing and bubbling radiators smokin a little, fans on, no leaks,ect.. and the temp gauge is all over the place, when i give it some gas the temp gauge shoots right up to hot and then back down to the middle like a damn tach this ***** wierd. i took the the thermostat out to see if it would over heat and it did the same thing. what im wondering is would my downpipe cause this if its to close to my radiator. heres some pics and tell me if you think its to close. it is touching the radiator but very little at the bottom . i was thinking of wrapping the DP but would that be enough. also i was running just water no antifreeze
the motor is
b20/vtec
85mm bore wisco pistons
pauter gsr rods
gsr crank
GoldenEagle HD sleeves
skunk2 stg 1 cams
h22 LMA's
oversized valves
P&P gsr head
BBK intake mani/TB
top top mount manfold
precision SC6176
82a/r exhaust
etc. ect. ect...
Old Aug 18, 2007 | 09:04 PM
slowcivic2k's Avatar
Default Re: over heating problem (ghettochild)
Is the cooling system fully bled? If you have air pockets in the coolant it will cause the temp gauges to go nuts.
ghettochild
Jun 10, 2011 07:51 PM
rolledthatho
Feb 8, 2011 10:57 PM
JDM_CRX_PLEASE
Feb 1, 2008 03:30 PM
deepgreengsr
Jan 31, 2003 06:16 PM
SpoonCivic
Aug 7, 2002 05:19 AM
