Apexi VAFC2...
Old Aug 21, 2007 | 03:23 PM
civic_saints1's Avatar
Default Apexi VAFC2...
So I had a friend install an Apexi VAFC2 for my d16Y8, he said he would connect it but not tune it, so he did so. I now just use it to set my vtec lo-hi and hi-lo lower. Someone told me thats not a good idea. Should I take it off or tune it? Im pretty much stock...all I have is a Short Ram K&N Intake, DC Sports Header, 2.5" Cat-Back System, 7lb. Lightweight Fidanza Flywheel, and a Stage 1 Exedy Racing Clutch.What do you guys suggest?
Old Aug 21, 2007 | 03:46 PM
Padawan's Avatar
Darth ModerVader
Default Re: Apexi VAFC2... (civic_saints1)
If you want to spend the money having it tuned (since I assume you don't have access to a dyno or wide-band O2), you will achieve some gains, though probably not enough to justify the cost.
Old Aug 21, 2007 | 06:04 PM
doood's Avatar
been there done that
Default Re: Apexi VAFC2... (Padawan)
take it out and use it as a paperweight
Old Aug 22, 2007 | 06:21 AM
Default Re: Apexi VAFC2... (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">take it out and use it as a paperweight</TD></TR></TABLE>
Dude, whats paperweight? What do you guys recommend for extra power without going forced induced?
Old Aug 22, 2007 | 12:55 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_saints1 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, whats paperweight? What do you guys recommend for extra power without going forced induced? </TD></TR></TABLE>
A good cam, perhaps some headwork, higher-compression pistons, etc.
At this point, extracting a decent amount of power out of your D-series without forced induction is not going to happen by simply bolting parts on.
Old Aug 22, 2007 | 02:26 PM
The_Head's Avatar
It has more value than that.
Old Aug 22, 2007 | 02:35 PM
Padawan's Avatar
Darth ModerVader
Default Re: Apexi VAFC2... (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">It has more value than that.</TD></TR></TABLE>
Indeed, but people often like to exaggerate to try to make a point. While the V-AFC certainly isn't the best option for tuning, it nevertheless is effective when used properly.
Old Aug 22, 2007 | 02:39 PM
The_Head's Avatar
Yeah, I like how you can see engine vacuum, and if you don't have a tach it will show you rpms if you want. I used on in my '87 Teg and decreased fuel in the lower load/rpm ranges to increase fuel mileage a bit.
If you can find one for cheap go for it. But if bought new, there are better tuning options.
Old Aug 24, 2007 | 02:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I like how you can see engine vacuum, and if you don't have a tach it will show you rpms if you want. I used on in my '87 Teg and decreased fuel in the lower load/rpm ranges to increase fuel mileage a bit.
If you can find one for cheap go for it. But if bought new, there are better tuning options.</TD></TR></TABLE>
I already have it bro...
civic_saints1
Aug 22, 2007 12:50 PM
civic_saints1
Aug 21, 2007 04:10 PM
civic_saints1
Jul 27, 2007 08:24 PM
dan's integra
May 4, 2006 10:20 PM
twobit
Apr 17, 2005 06:15 PM
