b18c5 problems w/ ecu n hondata!!!!!
Old Aug 22, 2007 | 08:14 PM
tunerkid07's Avatar
Default b18c5 problems w/ ecu n hondata!!!!!
k ive been helpn out on workn on a type r n has hondata, kk heres the deal, around a week ago the car would start n run for about a sec then turn off, so..... we let it sit kinda waiting to work on it, the p28 acted as if it was fried about a week ago n wouldnt let the car run, also was only throwing a check engine when the car was on. week went by n we started messn w/ it n put the p28 back in, it started n ran perfect after we changed a setting on the hondata off of 50RPM lmao, but later on today, went to drive it n now its doin exact thing, the car starts for about a sec n then turns off, its throwing the code 15 but when whe change ecu's to a ctr ecu w/o hondata it starts n runs decently. ne ideas, think a pin is loose in the ecu? ne suggestions?
Old Aug 22, 2007 | 08:27 PM
vxhatched's Avatar
sounds like you have short some where in the solder joints in your hondata. If stock ecu runs perfectly it can happen I have a bunch of friends that tune hondata.
Old Aug 23, 2007 | 10:56 PM
tunerkid07's Avatar
Default Re: (vxhatched)
would that make the car not run if the shoulderjoints on the hondata box are messed up?
Old Aug 28, 2007 | 02:43 PM
tunerkid07's Avatar
Default Re: (tunerkid07)
BUMP!@
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
SovXietday
Jun 30, 2007 10:08 AM
CA18DORI
Dec 23, 2005 05:19 PM
aziz93
Aug 16, 2004 08:29 AM
jiahanhao
Apr 6, 2004 04:41 PM
