Wideband not reading............
Old Aug 21, 2007 | 08:17 AM
crxking1's Avatar
Default Wideband not reading............
Hi guys, I just installed an AEM wideband A/F gauge in my CRX. It seems to work fine when I hit about 4000 rpm but it only flat lines between 1000-4000 rpm. i'm running a chipped ODB0 ecu with high compression pistions. I also just installed a Fields hyper SFC. Is it a case that im running lean at that point or something with the gauge. Any info is well appreciated.
Old Aug 21, 2007 | 11:32 AM
Bakeoff's Avatar
What do you mean it flat lines? Pegged rich or lean?
I would go back over the wiring. It's really pretty simple. Power to the gauge, ground, the plug for the sensor, and the 1v output to the ecu.
What kind of A/F's are you seeing at start up? Is it fluctuating?
I know from personal experience that if you do not have the sensor plugged in, the gauge tends to sway pretty much at 14.5-14.9. When connected properly, you should see the ecu adjusting for proper A/F ratio at idle.
that-guy
Apr 8, 2011 09:04 AM
crxking1
Aug 20, 2007 01:41 PM
jlh911
Oct 26, 2005 07:21 PM
tianporn
Jun 29, 2004 04:39 AM
X2BOARD
Apr 1, 2004 01:50 PM
