ECU chipping
Old Aug 27, 2007 | 08:30 PM
shortshift89's Avatar
Default ECU chipping
can i chip a pr3 ecu?
Old Aug 27, 2007 | 08:54 PM
doood's Avatar
been there done that
Default Re: ECU chipping (shortshift89)
sure. what obd is it?
Old Aug 27, 2007 | 10:27 PM
Default Re: ECU chipping (doood)
its obd0. i was told it wasnt worth it to chip it? but then someone else told me its one of the easiest ecus to chip.
Old Aug 27, 2007 | 10:30 PM
doood's Avatar
you can chip it. there's just not as many tuning softwares available for obd0 like there is for obd1.
Old Aug 27, 2007 | 10:38 PM
okay, thanks alot bro i appreciate it!
Old Aug 28, 2007 | 05:22 PM
does anyone have a DIY for chipping a PR3? pgfmi.org isnt working
Old Aug 29, 2007 | 06:16 AM
crxking1's Avatar
I'm running OBD0 in my CRX. I got a chip from: http://ecu.ff-squad.com. I think you can also get an OBD0 chipping kit from http://www.xenocron.com
I'm always glad to know someone else is going through the same stuff as me. You can PM me for some info if you like......
Old Aug 29, 2007 | 06:31 AM
zCivic's Avatar
Default Re: ECU chipping (crxking1)
OBD0 PR3 you have to remove the orginal 28pin Chip (which is soldered in) and then you just place a new socket in the ECU and then can swap chips easier/quickly. If you have not desoldered I would strongly consider checking with someone to do it because its a solid chip with 28legs all soldered. I have seen one distroyed by someone who thought could just rip it out. Not saying you can't do it but you will need a soldering iron, desoldering iron (dont waste time with braid I had no luck with it) a ZIF or somesort of 28 pin socket and a replacement rom. Hit me up if intrested.
Charlie Moua
10
Mar 14, 2010 08:50 AM
matt94z
Dec 3, 2007 02:48 PM
InJ3cted
Apr 25, 2005 06:57 PM
dohcnotec
Sep 3, 2004 09:09 AM
Kid1320
Jun 30, 2004 04:29 PM
