Cleaning the inside of the Head?
Old Sep 2, 2002 | 06:27 PM
BigDaddyRich's Avatar
Default Cleaning the inside of the Head?
I just popped off my ZC valve cover and that SOB is so gummy and nasty in there. It looks like a cruddy old BBQ grill
Can I clean the internals of the head by spraying carb cleaner on it without damaging anything? and just drain the used cleaner and loosend crud out of the head and relube the internals with some Mobil1? IF not what do you recommend in place of this ghetto idea Thanx.
Old Sep 2, 2002 | 06:39 PM
kinesistech's Avatar
Default Re: Cleaning the inside of the Head? (BigDaddyRich)
Everything will just drain back into the block if you do that. Instead what you should do is remove the head then clean it. Then put it back on freshly lubed.
Old Sep 2, 2002 | 06:58 PM
Default Re: Cleaning the inside of the Head? (kinesistech)
oh sorry.. I forgot to mention that I will be pulling the head off my bad!! once its off I guess I will soak it with carb cleaner and let it drain.. then reube it.
Old Sep 2, 2002 | 06:59 PM
StyleTEG's Avatar
Try running some of this -> http://www.auto-rx.com/
cleans up engine sludge, that sounds just like what you described.
WishinItWas
Aug 22, 2007 02:58 PM
ramrod
Sep 23, 2005 06:28 AM
275Performance
Dec 21, 2002 08:11 PM
AshlandSi
Nov 9, 2001 06:52 AM
