mysterious CEL 73 on GSR
Old Sep 2, 2002 | 11:55 AM
Y2KGreenGSR's Avatar
Default mysterious CEL 73 on GSR
Ok i went drag racing about a month ago and must have over-reved the motor by shifting into 2nd instead of 4th. The motor started ticking more than usual (haven't had a valve adjustment in a while) and it was throwing a CEL. I brought it home and pulled a CEL 73 which happens to be the infamous "cylinder 3 missfire"
Today i decided to check out the motor armed with a leak-down tester and a compression tester.
The leakdown on cylinder #3 came to show a 5% pressure decay and i couldn't hear any air leaking from anywhere except a very little around the sparkplug threads where the hose wasn't seated. The compression test registered at 190 psi for cylinder #3 while the other 3 cylinders registered around 195 psi.
As far as I can deduct the internals of cylinder #3 are pretty acceptable.
I also inspected the plugs and made sure the #3 plug was getting spark. The #3 sparked fine but with a orange tinge to the spark color.
I put it all together, cleared out the ECU and took it for a test drive. Same ticking and when I pulled into the driveway the CEL came back on again.
All signs point to a bent valve but the diagnostics don't really prove that, and I'd hate to pull the head to find out it was something else.
Can somebody please help, am I forgetting something?
Thanks in advance
Old Sep 4, 2002 | 12:27 PM
Default Re: mysterious CEL 73 on GSR (Y2KGreenGSR)
up up up I really need some help here
Old Sep 4, 2002 | 03:33 PM
salbaje's Avatar
what code is it??http://www.c-speedracing.com/faq/06.html
Old Sep 4, 2002 | 04:00 PM
Sonny's Avatar
It's a shot in the dark, but a lot of Greddy turbo users get a code 7x if their injector seals are not sealing right. The Greddy kit comes with RC injectors that replace the stock injectors and the fit isn't quite the same.
Sonny
Old Sep 4, 2002 | 07:07 PM
Default Re: mysterious CEL 73 on GSR (salbaje)
It's a code # 73 for an OBDII Integra, which is a "Cylinder #3 Missfire"
hmm i'll check the injectors tomorrow
Just picked up an automobile stethoscope (sp?) and I think i'm going deaf from listening to my motor for hours.
[Modified by Y2KGreenGSR, 8:09 PM 9/4/2002]
MeanusGeneus7
Honda CR-V & Element
14
Sep 18, 2012 08:35 PM
Tyteg
May 16, 2007 07:30 AM
SHystrdyGSRtdy
Sep 7, 2005 08:51 PM
LudeyKrus
Feb 23, 2005 02:22 PM
Y2KGreenGSR
Sep 5, 2002 11:20 AM
