Advice On Changing Brakes?
Old Sep 1, 2002 | 04:01 PM
1HotHonda's Avatar
Default Advice On Changing Brakes?
I need to replace the front rotors/pads and rear drums/shoes in my '98 Civic EX... The car has 119K on it, and I'm sure I'm going to have rusted/stuck parts... Any advice on doing this, other than getting some PB Blaster? I'm especially worried about the 2 phillips screws that hold the rotor on... All I should need is a screwdriver of appropriate size and I should be all set, right?
Old Sep 1, 2002 | 04:10 PM
94gsr's Avatar
Default Re: Advice On Changing Brakes? (1HotHonda)
The screws are much easier to deal with if you get a #3 phillips screw bit, a socket for the bit to fit into, & a ratchet to turn the socket.
Old Sep 1, 2002 | 04:21 PM
Kamin's Avatar
Default Re: Advice On Changing Brakes? (94gsr)
you need an impact driver for the screws on the rotor
(a screw driver where you hit the end with a hammer and it turns the screw)
MachAF
Suspension & Brakes
May 11, 2009 03:05 PM
drew2
Dec 26, 2007 08:57 AM
slowB20ej8
Dec 13, 2007 03:20 PM
Rywire
10
Jan 12, 2004 11:50 AM
dcb0821
Apr 13, 2002 09:40 PM
