timing belt and cam question
Old Aug 30, 2002 | 08:49 AM
takeheed's Avatar
Default timing belt and cam question
when i sat the cams back in, the alignment marks on the gears were off kinda facing downward toward each other like this \ / when there suppossed to be like this __ __ so i turned the gears by hand so they are the way they are supposed to be along with the crank alignment mark on the oil pump.anyone else have to do that?
also the new timing belt seems a little loose even with the tensioner bolt torqued to spec. am i just paranoid? thanks in advance (1st gen b16)
Old Aug 30, 2002 | 08:55 AM
legendboy's Avatar
Default Re: timing belt and cam question (adamjoey)
<A HREF="https://honda-tech.com/zerothread?id=258040
" TARGET="_blank">https://honda-tech.com/zerothread?id=258040
</a>
Old Aug 30, 2002 | 09:01 AM
94CivicSi's Avatar
Did you spin the motor backwards (4-5 teeth is all you need) with the tensioner loose to take up the slack in the belt?
Can't help you on the cam gear question. I've only got 1.
Old Aug 30, 2002 | 12:22 PM
takeheed's Avatar
Default Re: timing belt and cam question (94CivicSi)
thanks!!!!!!!!
VTEC_Du_Ma_Mai
Jun 28, 2007 12:11 AM
DeDonDeRosa
Mar 22, 2006 12:50 PM
spcrxracer
Mar 7, 2005 08:48 AM
lazykiwi
Apr 17, 2004 11:12 AM
zueke
Nov 28, 2003 08:38 PM
