trouble starting
Old Aug 31, 2002 | 03:18 PM
RedDawg's Avatar
Default trouble starting
the last few days i've noticed that when i go to start my car i need to pump the gas pedal to get it started, ive never had to do this before. Anyone know what i should check??
Old Aug 31, 2002 | 09:07 PM
PnX-R's Avatar
Default Re: trouble starting (RedDawg)
Hmm.. You have to pump the gas pedal to get it started..?.. I don't know.. I would guess the fuel pump or the fuel injector main relay.. But you might want to check the oil also. Pull out the dipstick and take a whiff of it. Does it smell somewhat like gasoline. If it does, I believe it should be the fuel pressure regulator's vacumm diagphram. But that's a wild guess.. I hope some of this helps..
Old Aug 31, 2002 | 11:43 PM
tinkerbell's Avatar
Default Re: trouble starting (PnX-R)
wild!
RedDawg - all you have to do is pump the acel? is this when hot or cold or always? any other problems?
full fuel tank?
t..
Old Sep 1, 2002 | 09:33 AM
RedDawg's Avatar
Default Re: trouble starting (tinkerbell)
the gas tank is about 1/4 full, i only need to pump the gas pedal when the engine is cold. To me it sounds like its not getting enough fuel so possible bad injectors??
is there anyway i can check the injectors?
Old Sep 1, 2002 | 03:21 PM
tinkerbell's Avatar
start basic and then get more complcated saves time and money...
replace your fule filters, check for kinked fuel lines etc.
its funny - you have injection, so pumping hte gas doesnt do anything to the fuel.
it ONLY opens and closes the throttle.
this signals hte TPS sensor and MAP sensor and the ECU works out hte fuel...
you can get your injectors cleaned and balanced if you think that is the problem...
hth,
t..
lmananT
Jun 4, 2008 10:56 PM
The Dirty EJ1
Jul 8, 2007 05:27 PM
lsvtec95
24
Jun 3, 2007 12:03 AM
Shaun
Jun 22, 2006 03:24 PM
gnar kill
Nov 18, 2005 02:09 PM
