help with clutch problem please.
Old Aug 29, 2002 | 04:52 PM
Malachi's Avatar
Default help with clutch problem please.
i just finished swapping an obdII gsr into a 92 cx. i finally got it running, put it on the ground and when i went to move nothing. the clutch feels just like it should, but when you let out it still acts like its still pushed in. i can sit with the clutch out and push it into every gear. any ideas?
Old Aug 29, 2002 | 05:55 PM
tinkerbell's Avatar
Default Re: help with clutch problem please. (Malachi)
did you put the driveshafts in? JK!
is it cable or hydo?
does it make any weird noises?
t..
Old Aug 29, 2002 | 06:28 PM
FUP23's Avatar
New User
Default Re: help with clutch problem please. (tinkerbell)
Sounds like the fork inside the tranny may not be working right with the throw out bearing ...Maybe the slave cylinder isnt hooked up right either ?
Old Aug 29, 2002 | 06:38 PM
Malachi's Avatar
Default Re: help with clutch problem please. (Devin17)
its hydro. the throw out bearing is brand new. the slave was hooked up fine. it doesnt make any noises at all.
Old Aug 29, 2002 | 07:03 PM
FUP23's Avatar
New User
fawk ....is your linkage connected ? basicaly the clutch isnt enganging
Is the clucth totattly fried ???
Bad clutch alignment ??
Did you bleed the clutch ??
[Modified by Devin17, 11:06 PM 8/29/2002]
[Modified by Devin17, 11:09 PM 8/29/2002]
Old Aug 29, 2002 | 09:07 PM
Malachi's Avatar
if the tranny is mounted it should be aligned, but im dropping the trans this weekend to figure it out. could having the disk in backwards cause this? oh, yeah i did bleed the clutch.
ricekiller1
Sep 9, 2007 12:34 PM
renes
Nov 21, 2005 11:25 AM
Hondasaurs
May 28, 2003 08:32 AM
H3rsh417
Mar 14, 2003 12:51 AM
