LS/vtec rods???
Old Aug 31, 2002 | 06:20 PM
EG6owner-T's Avatar
Default LS/vtec rods???
What is the recommended rods I should use when I do my ls/vtec?
Eagle? If so, what specs and description, like should i get the si or gsr ones?
tryin to make this motor last for a while.
What else should I do to the bottom end?
Old Sep 1, 2002 | 07:39 AM
EG6owner-T's Avatar
Default Re: LS/vtec rods??? (EG6owner)
ttt
Old Sep 1, 2002 | 08:40 AM
BROOD's Avatar
If your replaceing the pistond with aftermarket ones, you can use an aftermarket rod. Crower, Eagle, Paluter, ect. I suggest Eagles, they are a good value for the money compared to the others.
If your using oem Honda pistons that you need to use oem rods. The difference is in the piston pin design. Aftermarket rods use slip fit pins and retainer clips to hold the pin in place. OEM rods use a machine pressed pin to hold it in place, there are no machined grooves in the pistons for any retainers. I have see OEM pistons modified by adding retainer clip grooves but I really don't feel great about that idea. You have to decide.
If you are going to go with OEM rods you stick to the LS or B20 rods, definetly change the weal oem rod bolts out for ARP bolts, possibly have them shotpeened if you like. If you are going with after market rods you should order Integra LS rods.
Good luck, try searching old archived posts....alot of the info you will need is in there
[Modified by SLPR, 9:40 AM 9/1/2002]
Old Sep 1, 2002 | 01:52 PM
dohcsideSi's Avatar
i'm gonna go out on a limb and say you should prob get LS rods for your LS block!!!
Nonvtak monster
Oct 31, 2013 09:13 AM
1995Civiccx
Jan 14, 2008 06:26 PM
Mr. Self Destruct
Oct 13, 2005 09:32 AM
b16vtecsol
17
Nov 11, 2003 05:27 PM
untitled
Jul 4, 2003 09:50 AM
