Which timing belt? (Did Search)
I was wondering if someone can help me out on this one. I was looking to get a new ITR/GSR water pump. I know that there are more teeth on the ITR/GSR vs. B16A (22 vs. 19). But my question is Can i use a B16A timing belt or should i be using a GSR/ITR??? I can find any info on this. I did searches on 'timing belt' and 'water pump'. Can someone help me out.
which engine do you have? if you have a B18C then use a B18C timing belt as there are more teeth on it than on the B16A belt (3 or 4 more), if you have a B16 engine then the GSR/ITR water pump wont fit as they have a different bolt pattern as far as i know.
[Modified by mugenracer, 5:15 AM 8/30/2002]
I have a JDM B16A. I just went and looked at my water pump and it has a stamp on the pulley '22T'. Well what should i do now??? Do all VTEC water pumps 22T??? I starting to get very confused??? So does ITR/GSR flow more B16A water pump??? If it does how does it flow more??? Don' t they have the same amount of teeth??? Is it because of the longer timing belt???
here you go...
water pump for B20 & the laws of physics...
https://honda-tech.com/zerothread?id=240352
this should do it...
t..
t..
So just to clear this up and end the thread...i should get a 92-93 gsr water pump and del sol vtec timing belt??? Could i use a 99-00 si timing belt??? Thanks guys.
Thanks Tinkerbell. It makes sense what your thread talks about.
you need a B16A pump and belt.
t..
sorry that should read - you needa 22 tooth water pump and a B16A (Del Sol) belt
that is ANY belt for a B16A - but only B16A...
LAST EDIT _ promise!
[Modified by tinkerbell, 5:22 PM 8/30/2002]
[Modified by tinkerbell, 5:23 PM 8/30/2002]
[Modified by tinkerbell, 5:24 PM 8/30/2002]
t..
Tinkerbell,
Look at raene post...he says that i need a 92-93 gsr water pump. Its the only one that fits a JDM B16A(1st Gen.)? Do you know if this is true?
Tinkerbell,
in your case you need a short belt (B16A) and a 22 tooth pump (B16A).
from any B16A engine, JDM, USDM, Europe...
the GSR 22 tooth pump is same as B16A tooth pump.
it will be easier for you to ask for a GSR pump cause that is what it would be commonly refered to in your country (i assume you are in USA?)
HTH,
t..
Tinkerbell,
HTH in future..
t..
PS i see you are Canadian - sorry!!!!
[Modified by tinkerbell, 10:15 AM 9/2/2002]
Powered by VTEC
Dec 12, 2007 03:38 PM
