99 ls head
Old Aug 29, 2002 | 07:42 PM
darkirony's Avatar
Default 99 ls head
im buying a 99 ls head from a guy, what bottom end would fit this. i can get ahold of a 93 ls bottom end but will that work. or do i have to stick with 99 and up.
Old Aug 29, 2002 | 07:58 PM
phatcivic99's Avatar
Default Re: 99 ls head (darkirony)
man dont buy the head.. what are you going to use it for an ls motor...if anything get a vtec head and save the money of buying it later. unless you just want to do turbo ls dont get it, it is a waste of money..
just my .02
Old Aug 29, 2002 | 08:03 PM
darkirony's Avatar
Default Re: 99 ls head (phatcivic99)
i want to turbo it but do a complete build up on it. bore, cams, pistons, heads, etc. i heard turbo on it for what im going to do would be a beast. so your saying go with the vtec block
Old Aug 29, 2002 | 08:07 PM
lazy bum shaughn's Avatar
If it's a good deal then go for it. Newer LS heads will add a little more power than teh 93.
Old Aug 29, 2002 | 08:50 PM
Initial DA6's Avatar
i think what phatcivic was referring to was a ls/vtec setup. it consists of using a slightly larger displacement B18a/b block with a high revving vtec head.
if you just want to turbo a non-vtec engine, then the 99 ls head will work fine with a 93 block since it will have a safer (lower) compression ratio and blow-by from excessive overlap won't be as big a problem.
i'm not sure what year your chasis is, but its supposedly illegal to put an older block in a newer chasis. so if your car is 93 or older then it should be fine. if its 94+, then technically it should be illegal. just something to think about......maybe. HTH
Old Aug 29, 2002 | 09:02 PM
darkirony's Avatar
Default Re: 99 ls head (Initial DA6)
its a 95, i was going to get a b17 put in therebut the damn guy never contacted me. and i believe it was the cable clutch on that engine. if i was able to get it can i switch it over to the hydro. not really worried about putting an older engine in there
wes7side5o
Dec 6, 2007 07:07 PM
Cyphear
May 3, 2007 09:35 PM
redlseg
Jun 29, 2005 09:34 PM
tfalconier
Nov 26, 2003 09:16 AM
