Jack points on center line
Old Aug 31, 2002 | 09:28 PM
SkyDaver's Avatar
Default Jack points on center line
When you want to put your car (99 Civic EX Coupe, in particular) up on jack stands, where do you jack up the car? The cheap Haynes manuals don't show any spot on the centerline, front or rear, where I could put an alligator jack.
I'm really hoping there's a spot where you can lift up the entire front or rear of the car.
How about lifting up the entire side? Any spots there?
Thanks.
Old Sep 1, 2002 | 10:30 PM
2000_Civic_Si's Avatar
Default Re: Jack points on center line (SkyDaver)
You can jack up the rear at the tow hook, and the front on the radiator support you well see this lower thicker metal peice that is towards the drivers side like 6" from the middle and you can use that to jack up the front. The plastic peice may be hiding it a little but it is there. just keep looking.
Old Sep 1, 2002 | 11:40 PM
joeseph's Avatar
Default Re: Jack points on center line (2000_Civic_Si)
, check your owners manual, it may be in there.
zsiya
Aug 18, 2011 07:19 PM
Sport_Injected
Sep 23, 2004 08:07 PM
mv10s
Apr 10, 2004 03:59 AM
BigZ88
Jul 24, 2002 12:23 PM
JL 74
May 3, 2002 09:26 AM
