help with clutch/tranny problem
Old Sep 1, 2002 | 12:49 AM
H23 Power's Avatar
Default help with clutch/tranny problem
tonight i was driving around when out of the blue my clutch pedal becomes useless
94 prelude si, bone stock, 150k mi...before this happened i had noticed it was a little hard to shift gears...not bad, but worse than my other honda's
so here's the deal:
when the car is OFF, you can change gears just fine
when you push the clutch, it does move the slave cylinder, so that is working...
when the car is on, you CANNOT change gears. Its like the clutch pedal is not doing anything. when the incident happened, the clutch felt like it got really soft, and still feels this way.
i actually have a h23 tranny/clutch in my accord that i can use for the replacement, but just wanted to get an idea of what it might be. Its a lot more work to remove the one from my accord if I don't have to (ie its a minor thing on the prelude I could fix for little money)
thanks guys
[Modified by F23 Power, 5:31 PM 9/1/2002]
Old Sep 1, 2002 | 02:32 PM
H23 Power's Avatar
Default Re: help with clutch/tranny problem (F23 Power)
well, i went to try and drive it home today and after a few stoplights it decided to work fine...but i still need to figure out what it was
Old Sep 1, 2002 | 02:56 PM
smokin rubber's Avatar
so here's the deal:
Does it also work fine with the engine running?
It does sound similar to my overheated clutch ,
Old Sep 1, 2002 | 03:32 PM
Gen4-5Door's Avatar
Sounds to me like the springs in the clutch disc center have come out. I have seen this several times on other models. Time for a clutch my friend.
Old Sep 1, 2002 | 03:54 PM
H23 Power's Avatar
Default Re: help with clutch/tranny problem (Gen4-5Door)
well, when the engine was on it wouldn't shift at all....
but for some reason it went back to normal...so who knows
maybe something got in the clutch line?
[Modified by F23 Power, 6:54 PM 9/1/2002]
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
kpjo4
13
Jan 6, 2010 12:47 PM
egpwns
Jul 2, 2008 06:28 AM
Geeq
Jun 5, 2004 01:27 PM
