Question for the Tranny experts...
Old Aug 30, 2002 | 12:23 PM
The_Head's Avatar
Default Question for the Tranny experts...
In the upcoming weeks I will be breaking open my Tranny to install a Quaife LSD... What parts should be replaced just "for the hell of it" since the Tranny is being opened up and its the most conveinient time to do so? Please provide part numbers if you have them available, TIA
Old Aug 30, 2002 | 12:37 PM
dubnine's Avatar
Default Re: Question for the Tranny experts... (xThexHeadx)
Output shaft bearing. And not inside the tranny, but change your throw out bearing, pilot bearing and maybe your clutch depending on its condition.
Old Aug 30, 2002 | 01:28 PM
BROOD's Avatar
Default Re: Question for the Tranny experts... (dubnine)
I'd also replace all the oil seals (axels, shifter rod, etc.) while you were at it.
During my Quaife install I replaced the ring gear bolts, diff bearings, all oil seals, and the output bearing. Good luck with your install
[Modified by SLPR, 2:29 PM 8/30/2002]
fobile missile
Mar 8, 2006 03:41 PM
hondatuner20
10
Feb 8, 2006 07:05 AM
CPR
Jan 5, 2006 11:02 PM
Bnjmn
May 13, 2003 08:30 AM
95c1v1cs1
Dec 3, 2002 12:24 PM
