D16Y8 intake manifold differences
Old Aug 29, 2002 | 06:45 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default D16Y8 intake manifold differences
i would love to know what are the differences of the Y8 manies, automatic versus manual. i know litte about SOHC VTEC motors, but i know that the Y8 intake mani is the preffered one to use in all D series motors. i planning to mate that to the A6 head, using OBD0 wiring and ECM. which one do i need? pictures would be great as well.
i am getting together all info regarding the cheap built-up on D series motor. LS rods, B series TB, Y8 intake. will port all myself, including my A6 head.
thanks, sorry babbled post, kind of tired, damn school
stan
Old Aug 29, 2002 | 08:57 PM
Default Re: D16Y8 intake manifold differences (90crxsi)
pretty please? with a cherry on top?
Old Aug 30, 2002 | 12:16 AM
kinesistech's Avatar
The only difference between auto and man. y8's is the 3 wire iac on the auto. Its on the TB. The manual has the normal 2 wire sensor on the manifold. You need the manual one. If someone has obd2 cx, dx they can use the auto y8 manifold with the stock ecu because they also have 3 wire iac's.
A6 heads suck balzacks. You want the y7 head. The valves are both 1mm bigger and it is otherwise a direct bolt on. The problem with 92-95 civic heads is the bolt pattern for the distributor is different. The y7 head has the same pattern as the a6, and has a smaller combustion chamber for higher compression. Use a1 pistons and compression will be even higher. Have fun.
Old Aug 30, 2002 | 09:42 AM
Default Re: D16Y8 intake manifold differences (kinesistech)
thank you
stan
Old Aug 31, 2002 | 08:35 AM
PyroVTEC's Avatar
New User
You wouldn't happen to already have the Y8 intake manifold wouldja? Cuz I just *so happen* to have an extra one... throttle body, injectors, fuel rail, IAC solenoid, etc. and all... PM if interested!
- Pyro, who couldn't help but put in the shameless plug...
Old Sep 13, 2002 | 02:45 PM
DX187VTEC's Avatar
Default Re: D16Y8 intake manifold differences (PyroVTEC)
im lookin 4 a y8 mani........fill me in on the details..... IM me or something
Crosseman
Jan 14, 2015 05:29 PM
949
Nov 4, 2012 07:24 PM
actek988
May 1, 2012 12:50 PM
Chavy340
Apr 29, 2012 12:03 PM
trav143
Dec 5, 2008 02:13 PM
