is the IACV sensitive???
Old Sep 2, 2002 | 10:19 PM
_Endless_'s Avatar
Default is the IACV sensitive???
i recently took off the IACV of a bone stock 98 honda CRV just to look at the o-ring of the IACV. The car was running fine and i just wanted to take a look at the o-ring so i unbolted the 2 bolts and just look at the o-ring. after that, i bolted the 2 bolts and that's it. i didn't touch anything. but after re-installing the IACV, the car doesn't behave like it should be.
when i started the car, after all those years until i took off the IACV, it would go into fast idle right away and the rpm will be at 1500rpm or a little over. after o-ring viewing incident, it doesn't climb right away to 1500rpm, but just go to 1000rpm and very slowly climb up a bit. what did i do? is an IACV that sensitive? did i screwed up the car? How can if fix this? please take note, that i didn't disconnect anyhose or other stuff, all i did was unbolt the 2 bolts and then look at the o-ring and put it back in. no more, no less. heeeeelp....
Old Sep 2, 2002 | 11:26 PM
BoredNStroked's Avatar
Default Re: is the IACV sensitive??? (_Endless_)
It is very sensitive......you should tell it how beautiful it is and buy it roses....mabe you just hurt its feelings.......Is it on tight?....Try resetting the ECU.
Old Sep 3, 2002 | 07:28 PM
_Endless_'s Avatar
Default Re: is the IACV sensitive??? (BoredNStroked)
ok thanks. anymore?
Old Sep 3, 2002 | 07:44 PM
tinkerbell's Avatar
the answer is:
you can not look at o-rings.
you can look at them and then repalce them, but you cant just look at them...
t..
T3T495GSR
Jan 3, 2006 08:57 PM
BigRonDawg
16
Oct 9, 2005 03:27 PM
delguiner
Jun 21, 2004 08:03 AM
imaginary17
Mar 31, 2004 08:11 AM
