need help with rod bearings
Old Aug 29, 2002 | 10:14 PM
W.Zero's Avatar
Default need help with rod bearings
cant figure out which bearings to get. i have crower rods and i just got a set of brown honda factory bearings. i did a plastigauge check and it came out that i have the wrong bearings. thats why my motor is really hard to turn. i plaster gauge between the crank and the rod a few times and all where the same. its to tight. now i need help trying to figure out which bearing will get me in the .0015" range? i was told green. can anyone help would be highly appreciated! thanks in advance!
Old Aug 30, 2002 | 12:37 AM
kinesistech's Avatar
Default Re: need help with rod bearings (W.ZeroB18C1T)
What was your plastigauge measurement? That would help.
Old Aug 30, 2002 | 07:17 AM
Ri5e's Avatar
Buy ACL, they will put you within spec.
Ask Rocket, he sells them for $40 shipped.
Old Aug 30, 2002 | 08:58 AM
earl's Avatar
Default Re: need help with rod bearings (BG Boost)
Yeah, bearing colors don't work any more as they are tied into the size of the original rods. You can't change things inside your motor without effecting other things. ACL's work perfect with aftermarket rods and are higher quality than Honda stock ones. Buy from Rocket or me but that's the way for you to go.
Old Aug 30, 2002 | 09:32 AM
W.Zero's Avatar
Default Re: need help with rod bearings (kinesistech)
it was .001
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
pjr710
Aug 18, 2008 11:18 PM
y7turbo
Nov 1, 2007 08:21 PM
crexer
Apr 13, 2007 03:14 PM
reditr
Jan 17, 2004 12:39 PM
