P/steer help! ID this object
Old Aug 30, 2002 | 05:12 AM
Lyonel's Avatar
Default P/steer help! ID this object
In the midst removing power steering from my car, need to know what this plug is. Some kind of p/steer fluid pressure sensor??? It's screwed into the line that feeds into the pump and it's connected to an electrical connector on the other end. Do i need this? Can I just leave it disconnected?
TIA
Old Aug 30, 2002 | 12:55 PM
Lyonel's Avatar
Default Re: P/steer help! ID this object (Lyonel)
ttt
Old Aug 30, 2002 | 01:24 PM
jonsteR's Avatar
Lyonel: Would you mind making a how to on removing the PS stuff for G2s? I am going to be doing this in a month or so. Thanks.
Old Aug 30, 2002 | 01:53 PM
meept's Avatar
It's some sort of pressure switch...I had heard it raises the vehicle's idle speed a little, like if you turn the wheel below a certain engine RPM. Anyone else care to confirm?
Old Aug 31, 2002 | 02:11 AM
Lyonel's Avatar
Default Re: P/steer help! ID this object (meept)
Yep, you're right. A honda guru friend confirmed it for me. Was also given the bad news that if I did this conversion I might not pass 'warrant of fitness'
Looks like I won't be able to write up that how-to This was the original plan: https://honda-tech.com/zerothread?id=184202
vietdragontekx
Sep 19, 2012 10:06 PM
ftrms
Mar 31, 2010 07:18 PM
kroze
Jun 1, 2009 09:57 PM
zerovandez
Mar 18, 2007 08:53 PM
mikerbike
Oct 13, 2004 01:34 PM
