Torque specs for flywheel
Old Aug 30, 2002 | 02:08 PM
Dokta's Avatar
Default Torque specs for flywheel
I am ready to put my machined ITR flywheel on my B20Z that used to be an auto. Does anyone know what the torque spec/sequence is for the flywheel bolts? Is there anything else I should do/check before I put the flywheel on?
Old Aug 30, 2002 | 09:49 PM
TREVER's Avatar
Default Re: Torque specs for flywheel (Dokta)
Not being an A-hole but you need a Honda manual if your going to work on your motor. Also don't use the at flex plate bolts on a flywheel, there not long enough
Old Aug 30, 2002 | 09:57 PM
FUP23's Avatar
New User
Default Re: Torque specs for flywheel (TREVER)
use "blue lock tight" and tighen them as hard as you can with a 1/2in drive. You do not want these comn back out ! I think the tq specs are around 80 ...but i usualy do about 100
Old Aug 31, 2002 | 03:04 AM
ninesecrx's Avatar
Default Re: Torque specs for flywheel (Devin17)
torqe specs are there for a reason...its 80ft pounds on the flywheel and 19 on the pressure plate.
Old Aug 31, 2002 | 11:32 AM
Dokta's Avatar
Default Re: Torque specs for flywheel (ninesecrx)
I dont think you are an a-hole, but I don't NEED a honda manual to put a flywheel on, just the torque specs. And yes I do have 8 brand spanking new flywheel bolts. I have the 1/2" drive torque wrench which I will use to snug them up to 80 ft-lbs. Thank you for the info.
Old Aug 31, 2002 | 12:04 PM
kb58's Avatar
Banned
Not to be an A-hole here either, but yes, you DO need the manual or you wouldn't have asked!
madswapper
May 1, 2005 05:01 PM
HOLDEM1981
Apr 12, 2005 03:31 PM
AllMoToRB18c
Jun 29, 2003 11:24 PM
PatrickGSR94
Apr 18, 2003 09:18 PM
