B18c1 to 2.0l...worth it???
Old Oct 6, 2002 | 04:46 PM
speed's Avatar
Default B18c1 to 2.0l...worth it???
I currently have a B18C1 and am debating on resleaving it to 84mm to create essentially a 2.0l for a N/A settup.My question is will the motor then have A LOT more potential being 2liters?I figure it is a substantial investment going to 84mm considering the sleeving,pistons,and rods...will I just have then joined the 2 liter crowd or actually done something to make my car FASTER in every aspect.Given 2 motors with the same mods/compression, only one being 1.8l and the other being2.0l will it make the car substantially FASTER.I know it will make slightly more power/torque.My question is will it be much faster.Please no talking out your *** in your replies.Inteligent/experienced replies will be much appreciated.
Old Oct 6, 2002 | 04:53 PM
thegrinch's Avatar
Default Re: B18c1 to 2.0l...worth it??? (speed)
yes the motor will make more power. But with more displacement you will also need to upgrade the fueling as well. the overall outcome of making it a 2.0l will be about 15+whp. I have a friend that increases the displacement on the motor and gained 18whp. later he upgraded the injectors and program and mad a total of 23whp over his 1.8l configuration.
Old Oct 6, 2002 | 04:57 PM
speed's Avatar
Default Re: B18c1 to 2.0l...worth it??? (thegrinch)
Would it be safe to run the 2.0l config. temporarily with the stock injectors and a FPR?With a 12:1 comp?
Old Oct 6, 2002 | 07:12 PM
DefiantGSR's Avatar
if you want 2.0L...you need to bore it out to 85mm not 84mm
Old Oct 6, 2002 | 08:31 PM
lazy bum shaughn's Avatar
Default Re: B18c1 to 2.0l...worth it??? (DefiantGSR)
Yea, it will yield 1.9, unless you get an LS crank.
Old Oct 6, 2002 | 08:33 PM
Just curious, do you know how much torque he was putting out?
Old Oct 6, 2002 | 11:00 PM
polymath's Avatar
It might run with a FPR...but my B20vtec would not run with stock injectors. I had 12:1 compression.
I temporarily used 98 Prelude injectors, eventually buying some RC units.
Old Oct 7, 2002 | 04:55 AM
Shft@9GSR's Avatar
Default Re: B18c1 to 2.0l...worth it??? (Breakdancer)
I am running a 2.0L GSR motor 85mm with 11:1's and I was told torque would be around 150-155 ft.lbs.
Old Oct 7, 2002 | 07:12 AM
MikeSarr_GSR's Avatar
Default Re: B18c1 to 2.0l...worth it??? (Shft@9GSR)
If you have the time to tweak/learn and the money to do it right the setup would be soooo totally worth it. You could see mid 200s to the wheels with about 140-160TQ as well. granted, this is totally re-engineering the motor so expect to be in it about every 6months to a year to inspect the bearings... especially if you drive it the way you would want to... 12-13s in your integra with about 200 lbs of fat removed with an ITR tranny would not be out of the ballpark. tuned properly... you could still see 20-25mpg also. I would do more research and plan on doing it. Only remember this is not plug and play you will need to do your homework... talk to Halo, he also has a 2L 85mm car, last time we spoke he tuned his GSR motor on stock cams to 223/152 at the wheels.
[Modified by MikeSarr_GSR, 4:13 PM 10/7/2002]
Old Oct 7, 2002 | 08:20 AM
owen_the_soyboy's Avatar
Default Re: B18c1 to 2.0l...worth it??? (MikeSarr_GSR)
I want to do this with my GSR block next year, but will never probably dedicate to it. It is a big project and big money.
Old Oct 7, 2002 | 10:58 AM
Default Re: B18c1 to 2.0l...worth it??? (owen_the_soyboy)
that is fo sure
Old Oct 7, 2002 | 01:28 PM
thegrinch's Avatar
yeah he was making 148ftlbs of torque.
Old Oct 8, 2002 | 06:00 PM
StorminMatt's Avatar
It would probably be okay to temporarily use a FPR with stock injectors. An increase in displacement creates a more or less constant increase in fuel requirement across the whole RPM range.
Old Oct 10, 2002 | 05:58 AM
blazin's Avatar
Like I sais everyone I know that it'll make more power but will that make MUCH of a difference in terms of speed like in 0-60 and out of corners on a track?For example what I am looking for is say I race a car in a straight and the person always pulls a car length on me ...will going 2.0l now turn the tables?
Old Oct 10, 2002 | 08:59 AM
Default Re: B18c1 to 2.0l...worth it??? (blazin)
probably would turn the tables. A .2 liter increase is HUGE for the size in discussion here (1.8L setup). A guy with a B20 vtec pulled a few carlengths everytime from 0-80. All scenarios.. rolling, uphill, downhill, flat... pissed me OFF! But what I learned is that I will go H22 or B20vtec if I ever start another project.
low end torque provided by the bigger motors will be what gets you moving.. th ehigh rpm horspower of a CTR motor is great on a race-circuit, but a bigger displacement motor will beat it (just might not last as long at 9000 rpm as a 1.6L)
Old Oct 10, 2002 | 08:21 PM
do the math, more TQ EVERYWHERE... same gearing what do you think
will be self evident. its like putting 4-6 lbs of turbo on your engine if you
tune it right thats the diff we are talking about 150 tq to the wheels
by 6K rpm, keeping 130 of it to 8K on stock cams. still interested?
Old Oct 10, 2002 | 09:42 PM
OEMJDM's Avatar
Around how much money will it cose to resleeve a gsr to 2.0? im interested in this also
Old Oct 10, 2002 | 09:51 PM
Default Re: B18c1 to 2.0l...worth it??? (b20b4me)
http://www.goldeneaglemfg.com/sleeves.htm
dont forget to bring your wallet
95egGold
25
Aug 12, 2007 02:26 AM
thatwhiteguy
Jan 22, 2007 10:33 AM
igotnothin
12
Jul 10, 2005 01:47 AM
