breaking axels
Old Oct 6, 2002 | 09:03 PM
dmotoguy's Avatar
Default breaking axels
i have never had it happen, but can you tell me what happens when the axel breaks... like does the car pull to one side, or what, and what i should do at the track if it happens
Old Oct 6, 2002 | 09:38 PM
94-TVR-Civic's Avatar
Default Re: breaking axels (dmotoguy)
The most problem I have ever had with a axle being broke is when it's disconnected. When that happens the car doesn't even move but it still happens to do the top speed. If your axle is cracked you'll feel it in the car. My car had a tendency to be weak on the right side and steering was weak as well. It pulled a little but not noticebly a huge difference. I don't know if this will help you but it was worth a shot.
Old Oct 6, 2002 | 09:47 PM
Kamin's Avatar
Default Re: breaking axels (94-TVR-Civic)
the highest chance for breaking an axle is while you are launching.
if you are using street tires (meaning no slicks) dont worry about breaking an axle. it will probably never happen. but if it does, you may hear a funny *** noise and the car wont go anywhere. your speedo will still go up but the car wont move. it sucks. ive broken 2.
Old Oct 7, 2002 | 03:02 AM
visi0n's Avatar
Default Re: breaking axels (KAMiN)
hahaha friend has broken 3 axles on street tires...so yeah it happends...
when it happends while on the freeway like it did when i was driving my friends car the car will pull to the side and the steering wheel will viberate A LOT!
if it breaks on a launch you'll be going for one moment then going nowhere the next all while still in 1st gear...
Old Oct 7, 2002 | 09:27 AM
AWD: Jeff's Avatar
it happen to me. imo i always redline and peelout whenever i ran my car. after a while you hear clicking sounds when you turn. unfortunately i took mine for granted. i heard the click sounds even when i was driving straight. i didnt hear them snap, but the steering wheel was shaking side to side like i was shaking my car. i stop and after that my car wouldnt go forward. i got it fix a week later to find out that i broke both of my axles. i got scared that day cuz i could only go straight couldnt turn left or right. so if u hear clicking sounds its because ur cv boots tore and have been like that for a while. correct me if im wrong. but have it fixed right away.
my .02's
Old Oct 7, 2002 | 10:41 PM
d-wreck's Avatar
Default Re: breaking axels (sohc93hatch)
just buy new axles with a 12 month warranty and break them every 8 months
derek
Old Oct 8, 2002 | 12:09 AM
stockegsix's Avatar
my .02's
dude i hear a clicking sound whenever i make a turn it seems to be coming form the passenger side axle. i think its about to break. thanks for the info i will fix it this week. what axles should i use? can i use any b-series ones? i have a b16a in a 92 cx.
Old Oct 8, 2002 | 03:05 AM
xtrafastcivic's Avatar
Default Re: breaking axels (zzZZzzleeperCX)
does it make the clicking sound only when you turn and press on the gas??? or does it just keep clicking... i think it's happening to my friend's car...
Old Oct 8, 2002 | 10:19 AM
stockegsix's Avatar
Default Re: breaking axels (XtraFastCRX)
it only makes that sound whenever i'm turning, i know its that axle because this b16a came from my coupe that got hit on the front tire and the passenger side. can i use any 94-00 ls or gsr axles? how much is the average price(i need the passenger side, short one) any good place to buy one? anyone have a spare?
Old Oct 8, 2002 | 10:59 AM
WuWarrior's Avatar
Did you check your axle boots? make sure there is not any grease leaking.
I suggest you get a new axle anyways.
Old Oct 8, 2002 | 12:15 PM
satan_srv's Avatar
Default Re: breaking axels (WuWarrior)
If you are consistently breaking axles you need stronger motor mounts!
b18c1vtecdc2
Feb 13, 2017 10:42 AM
BigBoulda
Jan 25, 2006 08:13 AM
d_mina
Nov 27, 2003 12:09 PM
Fooman
Jun 3, 2002 09:14 PM
