honda gurus, 'need a lil help
ok, got a type r in my 5g, p28 ecu, jdm header...
the problem: car is possessed. sometimes the idle is fine, sometimes it goes up and down and throws a code (01= 02 sensor)>when i try to shut the engine off and start it back up, the light goes away. i've already tried 2 o2 sensors, one from a gsr, one from jdm type r. could a faulty o2 sensor cause the idle fluctuation? i've already checked vacuum leaks at the intake area by spraying some carb cleaner, it seems ok. i just need all the help/suggestions i can get right now. thanks
vet a voltmeter and check the wiring on the o2 sensor
make sure its not grounding out anywhere and check all connections.
if thats not it, swap ecu's it could be a bum ecu.
Guest
Posts: n/a
BUT, I got one more question.
Did you chip the ECU? If so, which program?
Also, check your grounds at the thermostat. Sometimes they look OK, but they are heavily corroded.
hondasport2000
Jun 19, 2004 04:06 PM
