ARP head studs for a b17a
Old Oct 6, 2002 | 04:50 PM
Brian_92GSR's Avatar
New User
Default ARP head studs for a b17a
Can anyone confirm that the b16a ARP head studs are the correct application for a b17a? Both motors have the PR3 head, so the only difference is the block.
Old Oct 6, 2002 | 06:50 PM
Sonic's Avatar
Default Re: ARP head studs for a b17a (Brian_92GSR)
I have never used ARP head studs on a B17A, but seeing as how the motors are 99% the same, I would guarentee that they will work. The head thickness is the same, so the only variable that remains is if the head bolts in the block are the same thread between the two motors, and ai am 100% positve that those are the same...in the end, yes, they will fit.
Old Oct 6, 2002 | 07:21 PM
New User
Default Re: ARP head studs for a b17a (Sonic)
I currently have a set for b18c1. The problem with them is they bottom out in the block to soon, and there is not enough thread left on top in the head. I believe it could be solved by cutting 4 or 5 threads off the bottom where to goes into the block, but I need a new set anyways.
Old Oct 6, 2002 | 08:21 PM
Crazy DA's Avatar
New User
they should be the same!! also, according to http://www.optauto.com , the part number for the new B16A head studs are 208-4601
[Modified by Crazy DA, 10:07 PM 10/6/2002]
big_joe1
Aug 3, 2009 12:56 PM
95civiccpdx
Oct 22, 2007 02:34 PM
TypeRbuild718
Sep 27, 2007 08:34 PM
Dancing is Forbidden
Jun 4, 2003 12:20 AM
paulzy
Jan 5, 2003 12:19 AM
