rev limiter problem
Old Oct 6, 2002 | 03:50 PM
solswap's Avatar
Default rev limiter problem
ok i drive a civic with a 98 gsr swap and a p72 ecu when i drive the car for the first 15-20 min. it pulls fine but after a little while it has a rev limiter at 6500 rpms and it stayes there in every gear does ne one know what the problem could be i already reset my ecu so its not that if ne one else knows what the problem could be let me know ASAP thanks
Old Oct 6, 2002 | 04:19 PM
S-Hall's Avatar
Default Re: rev limiter problem (solswap)
see what gas is in it. It may have knocked and the ECU picked that up and the ECU is in safe mode and will not let you do it. Its just a fast suggestion.HTH
Old Oct 14, 2002 | 06:34 PM
pornstarSR's Avatar
im having the same problem in my D series motor so im interested to see what people say
Old Oct 14, 2002 | 06:35 PM
Kamin's Avatar
Default Re: rev limiter problem (pornstarSR)
is your CEL on?
Old Oct 14, 2002 | 08:10 PM
vtec.dc2's Avatar
check/replace spark plugs, distributor cap and rotor
Old Oct 14, 2002 | 08:54 PM
MikeSarr_GSR's Avatar
Default Re: rev limiter problem (vtec.dc2)
something with your VTEC system is malfunctioning. that happenes when the VTEC oil pressure switch is un attached. could be that, or a broken sensor? if that were the case you would get a generic VTEC malfunction code like a 22 on my 99.
Old Oct 16, 2002 | 02:01 PM
pornstarSR's Avatar
Default Re: rev limiter problem (KAMiN)
my CEL is not one thats whats frustrating.
Old Oct 16, 2002 | 02:03 PM
pornstarSR's Avatar
checked plugs, fine.
replaced distributor, no change
havent yet replaced cap and rotor
but the engine ran fine on that cap and rotor a month ago....
the revlimit feels exactly like the ECU revlimit, so it doesnt seem to be a misfire.
Old Oct 16, 2002 | 04:57 PM
MikeMAN's Avatar
had the same thing on my old d16y8..
couldn't ever figure out why it did it.
2 days later, car ran out of oil! destroyed rod bearings....expensive lesson..
make sure u have oil!!
Old Oct 16, 2002 | 06:43 PM
vtec.dc2's Avatar
fried rotor was causing similar problem for me... like fuel cutof at 4K RPM, same as rev limiter... replaced it and car back to normal.
Old Oct 16, 2002 | 10:09 PM
can your car throw an engine code< maybe it is and you just have a broken light? jump the ECU and see
Old Oct 17, 2002 | 07:26 AM
93hybrid's Avatar
My b16 swap did this and im settin my self up to get flamed. but i didnt change my oil for awhile and the low oil pressure caused the vtec not to work. w/o the vtec your ecu goes into safe mode and limits at 6500rpm
Old Oct 17, 2002 | 09:09 AM
MikeMAN's Avatar
Default Re: rev limiter problem (civicrguy)
like i said, i would check ur oil
Old Oct 17, 2002 | 01:26 PM
pornstarSR's Avatar
Default Re: rev limiter problem (MikeMAN)
ohh i got oil i have a custon oilpan to hold 5.5 quarts
ohh yeah and i replaced the cap and rotor no change.
no my CEL light works, we have a mastertech here so i can read what the ecu see and check DTC's(hondas name for CEL)
still no light.
[Modified by pornstarSR, 10:27 PM 10/17/2002]
CivicSi95
19
Aug 23, 2010 01:54 PM
mikej94civex
Jan 9, 2010 02:13 PM
92eg6
Feb 9, 2007 09:12 AM
tatmark1
11
Aug 8, 2006 04:56 AM
Hondasaurs
Nov 15, 2002 01:46 PM
