cams-torque vs hp
Old Oct 9, 2002 | 11:15 AM
BigZ88's Avatar
Default cams-torque vs hp
Ok, in old muscle cars and such they have different cam profiles that are specifically geared to torque or hp. Normally both give u a lil of both but are designed to give more of one than the other. How? What is the difference in the profiles and why doesnt this work in imports?
Old Oct 9, 2002 | 01:08 PM
fuguman's Avatar
New User
Default Re: cams-torque vs hp (BigZ88)
taking a guess:
its prolly the duration of the valve being open vs the ammount it opens
i hope u get what i mean
excuse the crued drawing
Old Oct 9, 2002 | 02:29 PM
Muckman's Avatar
Moderator in Chief
Im not an expert in the subject.
But I think cams are more optimized mostly for high or low RPM.
low rpm being mostly torque and high rpm being mostly HP.
Old Oct 9, 2002 | 07:52 PM
EpDarks's Avatar
Default Re: cams-torque vs hp (Muckman)
It has to do with a lot of things, that picture above is basically correct.
Depends on when the cam starts to deliver it's mixture, how long it delivers it, and how much it delivers.
All depends on timing, duration, and how big the lobe is.
I think?
Old Oct 9, 2002 | 08:07 PM
Fly By Ya's Avatar
BAM!! http://www.howstuffworks.com/camshaft.htm
Old Oct 9, 2002 | 09:29 PM
TypeSH's Avatar
Default Re: cams-torque vs hp (Fly By Ya)
changing the profile changes where you make more/less torque. If you set it up to make more torque at higher rpms, the car produces more HP (since HP = (Torque*RPM)/5252 ). The tradeoff however, is that usually that means less torque is made somewhere else (since the cams were optimized for higher rpms), thus you lose low end torque.
Old Oct 9, 2002 | 10:27 PM
Lsos's Avatar
Honda uses this idea on their engines. They basically put in a cam designed for torque and a cam designed for power, and switch between the two as needed. VTEC.
Old Oct 10, 2002 | 05:15 AM
fuguman's Avatar
New User
Default Re: cams-torque vs hp (Lsos)
thats the beauty of vtec, u can have low end and good idle, but when u want power up high u can make the secondary lobe as big as you want and u'll get that nice kick of power. u can cam any car out, but it will idle funny as hell and wont be good at low end
typhoon
Feb 10, 2005 11:38 AM
Pelican
Jun 18, 2002 05:39 PM
ActiveAero
Jan 18, 2002 04:03 AM
