Anyone using this (QTEC)
Old Oct 9, 2002 | 11:27 AM
satan_srv's Avatar
Default Anyone using this (QTEC)
http://www.quicktimeperformance.com/qtec.htm
Electronically controlled dump tube. Perfect if you don't like exhausts need the flow on the track or the occasional street run
Anybody running one? Impressions? I want to hook it up to my V-AFC and have it open when I am in VTEC so I retain torque down low and have the flow up top
[Modified by satan_srv, 3:42 PM 10/9/2002]
Old Oct 9, 2002 | 12:19 PM
meept's Avatar
Default Re: Anyone using this (satan_srv)
A fairly old-school trick...used to see this on V8 muscle cars fairly often, though usually operated by a cable or a rod linkage. I'd wire it with an on-off switch as well though...just in case you need it to NOT open on VTEC activation for some reason
Old Oct 9, 2002 | 12:33 PM
satan_srv's Avatar
Default Re: Anyone using this (meept)
Yeah it's old school but still a good idea...well if I ruin the switch after the power from the VTEC wire I should be fine...I don't think there is any situation where I want it open when I'm not in VTEC
Old Jan 27, 2004 | 01:26 PM
Project92Hatch's Avatar
Bringing this thread back from the dead. But anybody else using this? I really want to know all motor wise.
Old Feb 24, 2004 | 04:31 AM
thehondaguru's Avatar
Default Re: Anyone using this (Project92Hatch)
Same thing from the dead also where else to buy it
Old Feb 24, 2004 | 10:34 AM
Default Re: Anyone using this (95 lude)
ttt
Old Feb 24, 2004 | 12:46 PM
99spanishGT
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it's old school but still a good idea...well if I ruin the switch after the power from the VTEC wire I should be fine...I don't think there is any situation where I want it open when I'm not in VTEC</TD></TR></TABLE> i think some of the guys down at full race are doing this!
Old Feb 24, 2004 | 02:48 PM
Default Re: Anyone using this (spanishlude)
Yeah, one day I cam across this and was like wow this could be worth a couple horses when I need it! I just want to find it somewhere cheaper than 150
Old Feb 24, 2004 | 09:15 PM
99spanishGT
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, one day I cam across this and was like wow this could be worth a couple horses when I need it! I just want to find it somewhere cheaper than 150</TD></TR></TABLE> you could probully make your own! that would be sick to rig it up so when u shift to 2nd it pulles a wire!
Old Feb 24, 2004 | 10:38 PM
TeH PLAYA's Avatar
I just found out about this from a friend. Pretty cool idea, but I have a question in mind about it...
Even with the QTEC open, wont some exhaust gasses still pass through the b pipe and muffler?
I thought about putting the stock exhaust back on (Civic Si) with this attached to a test pipe. Now that would be stealth!
Or a QTEC mated to a testpipe and GReddy EVO, which I currently have, haha ideas ideas
What do all ya think?
Old Feb 25, 2004 | 06:58 AM
Default Re: Anyone using this (THE PLAYER)
Yeah I think thats a good idea because I will be using this with a test pipe too and an apexi WS. That would be very nice the way you said it too.
Yeah I think some would go in the rest of the exhaust with it open but if you think about it it wouldnt be much because its gonna want to take the fastest/easiest route
Old Feb 25, 2004 | 07:18 AM
slammed_93_hatch's Avatar
alot of people run it ive seen pic of people putting it in on here and them. that guy in texas that has the video of him racing and hanging with the viper, he has one installed.
wouldn't suggest this for anything but FI.
Old Feb 25, 2004 | 07:37 AM
Default Re: Anyone using this (slammed_93_hatch)
wouldn't suggest this for anything but FI.[/QUOTE]
why not? I should have somewhere around 215 WHP with this motor. And with a JUN header that would help alot after vtec kicks in. I will have it hooked up to my EMS so that as soon as vtec opens or maybe after vtec's powerband levels out I will open it for some extra POWER! Not to mention scareing the **** out of some youg punk who thinks he is fast!
Old Feb 25, 2004 | 09:01 AM
becuase no matter how much hp you have NA your motor will still like some resistance.
Old Feb 25, 2004 | 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">becuase no matter how much hp you have NA your motor will still like some resistance.</TD></TR></TABLE>
yeah, your right, but I think it will get some kind of resistance because some of the gas is still gonna go through the rest of the exhaust.
Old Feb 25, 2004 | 08:16 PM
No this isnt very true in N/a you can benifit from this. Most likely you wont see huge gains on the dyno but at the track is were u'll see alot better results. If you think about all the people that run open header and dropping 2-4 tenths in the 1/4.
Old Feb 25, 2004 | 10:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">No this isnt very true in N/a you can benifit from this. Most likely you wont see huge gains on the dyno but at the track is were u'll see alot better results. If you think about all the people that run open header and dropping 2-4 tenths in the 1/4.</TD></TR></TABLE>
eeehhh i don't know about that.
and as far as still haveing some resistance it would be like you walking threw some cheap *** tolite paper. air is smart it will take the easiest route out
Old Feb 26, 2004 | 06:12 AM
and as far as still haveing some resistance it would be like you walking threw some cheap *** tolite paper. air is smart it will take the easiest route out</TD></TR></TABLE>
yeah I know. But it still will help. I do agree with you though on the FI setups. You will gain alot more power going FI with one of these. Not to mention it wont be as loud!
racenrockj06
Jan 24, 2004 08:03 PM
Brett
Feb 16, 2003 04:08 PM
THE SOUND OF VTEC
Apr 29, 2002 02:55 PM
dskull
Mar 26, 2002 01:41 AM
dskull
Mar 24, 2002 02:58 PM
