A bad bad Day..........
Old Oct 6, 2002 | 07:44 PM
b18c1civic95's Avatar
Default A bad bad Day..........
okay so i go and check a court date for a past ticket.....im leavng and get hit in the intersection. we exchange info and i head to my insurance co. I find out that i only have liability because full coverage was too damn expensive each month....and i got a new job and hadnt changed it back yet. so im pissed and hope that they find its his fault.... on the way home my exhuast bolts come out behind the header and the pipe falls down and starts hitting the ground so i pull over and grab some hose and put it through the ring of the o2 sensor to tie it up to the strut bar till i get home......then the hose gets sucked into the timing belt goes around the cam gears and kills the motor..... i crank it over a lil without starting it and keep getting out and pulling it out a little bit more like 3 times.......but on my way home the car barely runs and i had to kinda give it alot of gas to get it out of its powerless mode... So im thinkin its obviously the timing got messed up cuz the hose probably made it skip some teeth on the belt over the cam gears. but how do i figure out where it was? just use TDC marks???
Old Oct 6, 2002 | 11:16 PM
Big Bri's Avatar
Default Re: A bad bad Day.......... (b18c1civic95)
that sucks!! you need
Old Oct 7, 2002 | 03:00 AM
Stupid Ass's Avatar
Default Re: A bad bad Day.......... (Big Bri)
Ugh dude... I hope you didn't do any serious damage!
Old Oct 7, 2002 | 05:50 AM
92sleepR's Avatar
New User
Oh man. Talk about bad karma. Who did you f*!k, kill, **** off in a past life?
I feel for you man, I had a similar run of shitty luck back in June but it always gets better. Just take a breather and focus on the good things.
Mike
low91rex
11
May 9, 2007 08:09 PM
PINKS
Aug 9, 2006 02:44 PM
PINKS
Aug 9, 2006 02:22 PM
tyflip2
Apr 23, 2005 07:31 PM
yuckymucky
Mar 23, 2003 10:22 AM
