Q's spoon cams in b16a
Old Oct 6, 2002 | 03:54 PM
garagespecial
Guest
Posts: n/a
Default Q's spoon cams in b16a
what settings do most of you guy run on?
have your cam gears ever slipped?
PM garagespecial
Old Oct 6, 2002 | 04:16 PM
S-Hall's Avatar
Default Re: Q's spoon cams in b16a (garagespecial)
Well it's real importent to tighten the cams gears before installation or whilel doing it so that you know that they are tight. If worried about slipping dont put them on or just check and tighten then everyonce in awhile. but i have never had mine slip and i have revd to 9800rpm HTH
Old Oct 6, 2002 | 08:05 PM
99blackcivicSi's Avatar
Default Re: Q's spoon cams in b16a (S-Hall)
be sure to buy good quality cam gears also. A friend of mine put crower stage II cams in his car and put it all pack together i don't know what kind of cam gears they were but the bolts backed themselves out of the gears and it started to go to 0 to -10 to +10 over and over. So he took it back home and tightened them down agian thought it would be ok and went back out for another test drive well the vavles bent and when they opened up it smacked the spark plug breaking the whole end of it off in the combustion chamber so he has a hell of a mess.
BTW it is a GSR in a 92si hatch. Without the cams this thing ran mid 8's all day long in the 1/8th. very strong running car well or was.
blacK_Dc4
Northern California (Sales)
Mar 28, 2012 10:52 PM
blacK_Dc4
Mar 28, 2012 03:09 PM
MDintegra95
May 5, 2005 08:28 AM
pinota
Sep 6, 2002 09:39 PM
B2FiNiTY
Jan 17, 2002 12:50 PM
