Help!!! Engine problems...
Old Oct 7, 2002 | 06:51 PM
AutoXsi2000's Avatar
Default Help!!! Engine problems...
I have a 00 Civic Si. Just washed my engine yesterday. Of course I covered the fuse box, air intake, distributor, then let the engine dry for like 3-4 hours in the hot sun. Now, the engine sounds like it is misfiring. Can anyone relate to this problem? Could I not have gotten water in the distributor?
Old Oct 7, 2002 | 10:37 PM
d-wreck's Avatar
Default Re: Help!!! Engine problems... (mano77)
water in the area around the spark plugs, also clean the distributor and plug wires. if carbon gets on these it will cause it to arc to it, if you dont believe me take a pencil to your friend or enemies distributor
derek
Old Oct 8, 2002 | 04:59 AM
Default Re: Help!!! Engine problems... (d-wreck)
will do, i will check the spark plug area for water. thanks for the input.
Old Oct 8, 2002 | 06:41 AM
577HondaPrelude's Avatar
next time just use a wet rag
Old Oct 8, 2002 | 07:29 AM
MikeMAN's Avatar
Default Re: Help!!! Engine problems... (57STS)
could that have put him in "limp" mode? i had to reset my ECU...
that is what has happened to me a couple times (when i was a idiot with my old SOHC engine)
Sinner
Mar 2, 2006 07:49 AM
pr0jektdc2
Nov 27, 2004 06:42 AM
SOHC_MShue
63
Oct 11, 2003 11:44 AM
boondox_saint
15
Jul 17, 2003 11:16 PM
Comptech98GSR
Jan 25, 2002 05:05 PM
