Popping while on the spray...
Old Oct 8, 2002 | 08:57 PM
n2ohuffer's Avatar
Default Popping while on the spray...
What does detonation really sound like? I always heard it was a pinging, but when I'm on the bottle, it seems to have an odd popping. No loss of power, no odd holes in the block, just sounds like **** falling out from under my car. I know this sounds odd, but I've been a Honda parts man for 10 years, and no techs I know have any idea. Maybe something to do with bottle pressure? It was kind of cold last night...
Old Oct 9, 2002 | 04:37 AM
torran's Avatar
Default Re: Popping while on the spray... (n2ohuffer)
fuel pump going bad or bad plugs
Old Oct 9, 2002 | 09:34 AM
afterhourz's Avatar
you sound like you are leaning out. what type of nitrous kit do you have and is it wet or dry. how many shot, have there been any retards on timing
Old Oct 9, 2002 | 10:51 AM
ViZ's Avatar
ViZ
Default Re: Popping while on the spray... (afterhourz)
make sure you are using good gas nothing under premium
Old Oct 9, 2002 | 10:53 AM
sieger's Avatar
I had a D16Y8 that did that on the bottle. Then one day my number 1 rod went on vacation through the front of the block. Don't know if I was running too lean but I was using that ZEX kit. Still don't know about that thing. Anyway that's what happened to me. Since then I learned alot, like if I drive it everyday don't use NOS. Some guys do, but I gotta make it to work yunno? Good luck
Old Oct 9, 2002 | 12:05 PM
n2ohuffer's Avatar
Default Re: Popping while on the spray... (sieger)
it's a dry shot, 65 hp, Zex plugs, timing retarded 2 degrees...
Old Oct 9, 2002 | 12:17 PM
martini's Avatar
check the plugs, see if you are detonating.
nitroaccord105
Jul 18, 2007 12:32 PM
gsrtxjarrod
Jan 8, 2005 09:33 PM
XxDemonxX
Mar 9, 2003 08:57 AM
kefka
12
Dec 14, 2001 01:26 PM
vtec-nut
Nov 9, 2001 11:58 AM
