Rod bearings...
Old Oct 6, 2002 | 02:04 PM
optikal_blitz's Avatar
Default Rod bearings...
Hey i am looking at buying a 92 prelude si 4ws..the guy wants about 1900 for it.. price being so low becuse it has a bad motor. what's wrong with it is its rod bearings. I dont know what rodbearings are exactly or how much they will cost to be replaced and implemented. Anyone with extensive knowledge heres your chance to flex some knowledge on me.. i am friends with a mechanic but id like to know how much i would be looking at paying for fixing this car. hit me up on aim if its more convinient:: natakublitz. Thanks!
[Modified by JDM_Prelude, 6:08 PM 10/6/2002]
[Modified by JDM_Prelude, 6:09 PM 10/6/2002]
Old Oct 6, 2002 | 03:05 PM
earl's Avatar
Default Re: Rod bearings... (JDM_Prelude)
Well you are only looking at $50 for a set of rod bearings but the problem is what condition is the crank and rods. You won't know until you look at the rods and crank. If the motor has to come out because of other repairs, you are looking at $1500 to $2000 for a complete rebuild.
Old Oct 6, 2002 | 03:37 PM
x James Bond x's Avatar
Default Re: Rod bearings... (earl)
Does the guy know its the ROD BEARINGS? If Its the main journal bearings then your in for a whole lot more work. If its just the rod bearings and the crank is in good shape then its a pretty easy fix. If the crank is scored then its going to cost a bit.
If your looking for Performance the 4WS is not the way to go. You will have problems later when you want to do suspension mods.
jakscivic
Feb 21, 2013 08:27 AM
viera
Feb 19, 2010 12:09 PM
nkymain
11
Sep 22, 2005 01:25 PM
93slmdcvcsi
Mar 8, 2005 05:53 AM
Nextelbuddy
Jan 9, 2004 10:12 PM
