Timing belt slipped!!
Old Oct 8, 2002 | 03:49 PM
quis23's Avatar
Default Timing belt slipped!!
How do I go about geting both cams at tdc? I kow you have to rotate the crank to get the cams at tdc,but how do i know which one is correct and which one is off. The belt slipped cuz i had loose connection on my crank angel sensor.
Old Oct 8, 2002 | 04:00 PM
94gsr's Avatar
Default Re: Timing belt slipped!! (quis23)
There are arrows and/or slots marked on the edge of your cam gears.
Old Oct 8, 2002 | 04:02 PM
Finest's Avatar
Default Re: Timing belt slipped!! (94gsr)
If I remember correctly, the arrows on the cam gears should be pointing straight UP and the other marks should be pointing towards each other.
purgat0ry
19
Aug 22, 2012 04:27 AM
revolution920
45
Mar 26, 2011 04:47 PM
turboedsupe
Sep 19, 2008 04:32 PM
drumminforev
Oct 17, 2006 10:16 AM
