1/4 mile....lsd or 4.7 final drive?
Old Oct 9, 2002 | 01:45 PM
3rdGteg's Avatar
Default 1/4 mile....lsd or 4.7 final drive?
Say I have a choice of a b16 Tranny either with an lsd or one with a 4.7 final drive...which would help me burn up the 1/4 mile better? Also please school me on the advantage and functions of an lsd and higher final drives.
Tia.
Old Oct 9, 2002 | 01:52 PM
sieger's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (3rdGteg)
The 4.7 final drive will let you accelerate faster, but you will hit redline at lower speed. The LSD allows the tranny to put the power down on where the car gets grip. I would go with the B16 with LSD, especially if you spend most of your time on the road and not the strip.
Old Oct 9, 2002 | 02:00 PM
skunked's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (sieger)
I agree, go with the LSD tranny.
Old Oct 9, 2002 | 02:18 PM
Chris N's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (skunked)
LSD. Unless you are going to raise the redline a bit, then maybe the FD would be a better choice. If you are ONLY going to go with LSD or FD, I'd say lsd is the way to go.
Old Oct 9, 2002 | 02:28 PM
3rdGteg's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (1107)
So the lsd will help decrease my 1/4 mile times right?
Old Oct 9, 2002 | 02:33 PM
chri5's Avatar
Id get teh final Drive and add a quaife lsd.
Or the other way around, and ge the one with teh LSd and add a JDM 4.75 FD
Old Oct 9, 2002 | 02:34 PM
Project X's Avatar
They actually are 2 different thing. They shouldn't be compared rather should be a complement of each other.
But to answer your question, no... between LSD and FD, the FD will decrease your 1/4 mile more.
Old Oct 9, 2002 | 02:52 PM
3rdGteg's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (Project X)
So it's not worth getting lsd for drag racing? I thought it'll help my launches which could decrease my times?
Old Oct 9, 2002 | 02:55 PM
sieger's Avatar
You'll see a difference in 60' times but the 4.7 will affect the whole run.
Old Oct 9, 2002 | 03:03 PM
carl_aka_carlos's Avatar
if you get the LSD you'll leave two black strips when you leave the line...no more peg-legging which is what happens when you drag race with an open diff...only one wheel get's the power. if you drive your car as your daily driver the FD will make highway driving hell, and you'll have to shift more often. IMO, i'd go with the LSD...it'll also help you power outta the corners better too.
LSD
Old Oct 9, 2002 | 03:12 PM
sidan's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (carl_aka_carlos)
A lsd is definetly the way to go first mabey down the road go for a different final drive but you will love a lsd. you will at least take a couple tenths off your time according to how much you spin now of course.
Old Oct 9, 2002 | 06:53 PM
3rdGteg's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (sidan)
So does this mean I'm capable of launching my car at a little higher rpm without too much wheelspin? (I was launching at like 3500 before lsd.)
Old Oct 9, 2002 | 08:27 PM
to clarify...when you launch in an open diff equipped car (like yours) which ever wheel breaks traction first recieves all the power....works on the principle of following the path of least resistance. This creates what we call 'one wheel peel' A quaife LSD is torque biasing, so when one wheel starts to break traction, the diff automatically sends all the power to the wheel with the grip. Doesn't mean you'll be able to launch at a higher RPM, but it will help you maximize traction at lauch, and will definetly help you decrease you're 60 ft time.
Old Oct 10, 2002 | 02:02 PM
3rdGteg's Avatar
Thanks everyone for the replies, I think I somewhat got something out of this.
Old Oct 10, 2002 | 02:24 PM
CHEETAH's Avatar
Tia.
i was in the same predicament when dumping a swap into my del sol, had a lsd for b16a and a final drive, couldnt use both since the lsd was b16a pattern ... I chose the final drive because it really gets the car going and buss-some-*** on the road. Not everyone may like the 5Krpm in 5th ont eh highwya though.
Greg
Old Oct 10, 2002 | 03:18 PM
hoya_10fintec's Avatar
LSD...
Old Oct 10, 2002 | 03:21 PM
3rdGteg's Avatar
Default Re: 1/4 mile....lsd or 4.7 final drive? (CHEETAH)
Daaamn, 5k rpm on the highway? How do them people with the 4.785 ITR trannies do it? Daily Driving would suck then
I might not want to throw the final drive in later after all.
da6xsi06
Transmission & Drivetrain
Oct 6, 2010 04:47 AM
Charlie Moua
Apr 18, 2010 12:49 PM
essex
Jul 9, 2008 08:37 PM
NightHawkC5
Feb 27, 2003 10:58 AM
