code 7 when coasting in 4th or 5th...any thoughts?
Old Oct 9, 2002 | 06:08 AM
Jeff C's Avatar
Default code 7 when coasting in 4th or 5th...any thoughts?
whenever i coast in 4th or 5th at decent speeds, like going downhill or coming to a stop, it throws a code 7 at me. i have temporarily fixed it by coasting in neutal but is becoming a pain in the butt to have to shift out of gear whenever going down hill.
any thought?
Old Oct 9, 2002 | 09:49 AM
TurbodCX's Avatar
Default Re: code 7 when coasting in 4th or 5th...any thoughts? (Jeff C)
what is code 7?? maybe if you tell us what the code means we can help
brian
Old Oct 9, 2002 | 10:36 AM
sieger's Avatar
Default Re: code 7 when coasting in 4th or 5th...any thoughts? (TurbodCX)
Throttle position sensor.
Look here:
https://honda-tech.com/zerosearch
Someone else has had your problem I'm sure. You'll need a multimeter. Just search till you find the specs and test it out.
Old Oct 9, 2002 | 12:41 PM
Jeff C's Avatar
Default Re: code 7 when coasting in 4th or 5th...any thoughts? (sieger)
i know what it is. i wanted to see if anyone might know why it came on when i was coasting.
i already know how to test it too.
Old Oct 9, 2002 | 12:59 PM
sieger's Avatar
Ok then you're set. It's either misadjusted or bad.
alex_belarus
Nov 21, 2007 02:37 AM
Carbcivic
May 16, 2006 02:49 PM
ALLshowNOgoLS
May 4, 2006 02:19 PM
93b18civic
Mar 21, 2004 06:48 PM
