When is a fuel pump bad?
Old Oct 9, 2002 | 10:21 PM
EGTeK's Avatar
Default When is a fuel pump bad?
i was wondering because my cousin says it could be my fuel pump that is causing my car not to start. he replaced one on his teg and now it starts fine.
the thing is, most of the time my car will start up with no problem and run without dying. if the fuel pump can withstand that then it should be fine right? would it most likely be the main relay that is causing my pump to not come on sometimes? .. what is the difference between the fuel pump relay ad the main relay? and where is it located in a 92 civic? thanks
wwolf771177
Mar 25, 2013 02:54 PM
ALTERED4
Jan 31, 2009 08:43 PM
JimmyM86
15
Oct 18, 2007 08:44 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
Unjockable
34
Mar 3, 2004 07:38 AM
