cel goes away
Old Oct 7, 2002 | 09:06 PM
S13 slide's Avatar
Default cel goes away
ok when i drive around for a while i get a cel. and i go to check it by turning off the car and jumping the connector but the light doesnt comeback, only after driving a little bit, so how can i check the code? any ideas? thanks
Old Oct 7, 2002 | 09:37 PM
the DR.'s Avatar
Default Re: cel goes away (S13 slide)
check the light on the ecu, i think the code still flashes if the check engine light is not illuminated.. it should store the code at least.
Old Oct 7, 2002 | 11:39 PM
S13 slide's Avatar
Default Re: cel goes away (CIVICtypeS)
so i would check the light on the ecu the same way i would check the cel? jump the harness and turn the key? and how would i check a stored code? thanks
Old Oct 8, 2002 | 12:38 AM
B00ST2nR's Avatar
http://www.c-speedracing.com
goto FAQS and there should be instructions on how to check the CEL code and what it means.
Also, if you get a CEL and it goes away later on... that means the Car fixed the problem by itself, so that could be one of the options....
Old Oct 8, 2002 | 01:23 PM
S13 slide's Avatar
Default Re: cel goes away (Skunk2nR)
ok so i checked the light on my ecu and theres a light that blinks once. does the ecu normaly blink? or does it mean code 1? so thats the o2 sencor.
eclipsefirenos
May 18, 2009 10:11 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
smithbling
Nov 19, 2002 12:26 PM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
PM-Performance
Nov 30, 2001 10:53 AM
