Overheating Issues...
Old Oct 8, 2002 | 07:20 PM
flat-blk-HB's Avatar
Default Overheating Issues...
Ok My car will start to get hot after about 15-25 mins of driving.( SOMETIMES. Well I have replaced the thermostat and the rad. cap. Next on the list is the headgasket. My motor (D16Y8) used to have a turbo set-up before I bought it, and I am told that a turbo motor blows headgaskets more often..???..Another thing that is funny about my "overheating issue" is If I run the heater on low then it never,never,never heats up..Well it gets to normal temp..Also I know for a fact my fan is coming on. Another thing with my car running and the rad. cap off when I give gas the coolant is spayed out the radatior. Which I was told meant my headgasket.?? IS this correct? If you have any Ideas on what is causing my "overheating issue" then please let me know. Thanks for any help that you can provide
Old Oct 8, 2002 | 07:21 PM
rurkster's Avatar
Default Re: Overheating Issues... (!)
take it to a mechanic. usually theyll look at if for free in hope of business
Old Oct 8, 2002 | 07:23 PM
Default Re: Overheating Issues... (rurkster)
Yeah but they will proably just tell me proable causes.Thanks for the idea though.
Old Oct 8, 2002 | 07:43 PM
didyouhearthat's Avatar
Might be your water pump. My car is having that problem also, and i found a leak coming from the water pump. If you don't have a leak, the pump may not be circulating the coolant. I don't know for sure though. Making any funny noises?
Old Oct 8, 2002 | 08:11 PM
Default Re: Overheating Issues... (joeyb)
Not really any noises..definatly not a water pump noise..any other ideas? Have you heard of this...Just by having the heater on LOW the car keeping from over heating?
Old Oct 8, 2002 | 08:41 PM
tonyxcom's Avatar
you try flushing the coolant?
Old Oct 8, 2002 | 09:27 PM
shadowdawn's Avatar
Is there any fact to this? I want to know because until I can locate someone around me with a leakdown I can't rule out the possibility mine is blown (naturally praying it isent)
My reason for thinking this is I throw misfire codes occasionally, and even rarer (twice actually) coolant boils/bubbles but no resevoir overflow.
Old Oct 9, 2002 | 01:25 PM
Default Re: Overheating Issues... (tonyxcom)
No actually I havent..Could this be a good reason. I also heard you can get air in your cooling system? Is that true?
Old Oct 9, 2002 | 01:44 PM
sieger's Avatar
It could be your main bearings. Check for metal in your oil. That rotating assembly gets hot as hell when those bearings wear out and you will have an overheating problem. Not sure about the head gasket. All turning your heater on does is mask the problem by taking away some of the heat, if it is a nearly stock motor it shouldn't be doing this.
Old Oct 9, 2002 | 01:47 PM
Chiovnidca's Avatar
Default Re: Overheating Issues... (shadowdawn)
That's a pretty good sign of an unhappy headgasket.
Old Oct 9, 2002 | 04:01 PM
Default Re: Overheating Issues... (sieger)
Yea that would suck ballz if that was a problem.. But there is no metal in the oil. About the motor being nearly stock, I am not completey sure about this. It was a TUrbo motor before and i dont know what all was changed.
Also the motor set for a while in a shed uncovered..for about 5 months?
[Modified by !, 7:03 PM 10/9/2002]
Old Oct 9, 2002 | 06:05 PM
Turbo Powa's Avatar
why dont you look at your water pump. There is a bleed hole there. If you see any signs of fluidits your water pump. The water pump doesnt necessarily need to make odd noises. Also check for play on the pump. If thats not it your coolant might be bad. Check the coolant for any discoloration or any metallic pieces floating in it. If its not that. Then sorry bro... cant help yah!
[Modified by Civic LX 29, 3:06 AM 10/10/2002]
Old Oct 9, 2002 | 06:39 PM
Default Re: Overheating Issues... (Civic LX 29)
The water pump is fine and all, no sings of coolant leak from there. Well hell there is no signs of coolant leak anyhwhere on the motor. I am think I will just repalce the headgasket and put new coolant and all in the system. Hope then can solve my problem
Old Oct 9, 2002 | 07:09 PM
ghettochild's Avatar
I SAY JUST **** IN YOUR RADIATOR AND IT'LL COOL DOWN IN NO TIME.
TAKE IT FROM ME, I DO IT ALL THE TIME
Old Oct 9, 2002 | 08:13 PM
Default Re: Overheating Issues... (ek9beyatch)
Sounds like a good idea bro. I think I will try that one. Dont forget I got your radiator cap so I might get a lil of my **** on it.
Oscar Ponce
Feb 26, 2012 11:15 PM
ctr32
Aug 10, 2009 03:03 PM
Fighterinsnatch
11
May 21, 2007 02:43 PM
twenty
Jul 21, 2005 04:32 PM
bitr364
Jul 22, 2003 02:03 PM
