Starter is dead I think
Old Oct 6, 2002 | 05:12 PM
SlowB16's Avatar
Default Starter is dead I think
The car makes a loud tapping noise when I turn the key. Is that the starter? The last few days the car has been very slow to start as well. Also, how much do starters usually run? And which one do I get for a first gen b16? Cable tranny.
Old Oct 6, 2002 | 06:00 PM
toozuked's Avatar
Default Re: Starter is dead I think (SlowB16)
I had the same problem a year ago turns out it was the alternator not the starter. Easy way to check the alt. is to start the car then disconnect the neg on the battery if the car stalls its the alternator. If not then look at the starter.
Old Oct 6, 2002 | 06:53 PM
the DR.'s Avatar
tapping sound..? is it like a rapid clicking sound?
Old Oct 6, 2002 | 07:33 PM
Turbo Powa's Avatar
Default Re: Starter is dead I think (CIVICtypeS)
If it is.. then its your starter.
Old Oct 7, 2002 | 12:14 AM
sieger's Avatar
Default Re: Starter is dead I think (Civic LX 29)
Just make sure the battery has a good charge.
Old Oct 7, 2002 | 12:28 AM
Slurp56's Avatar
Default Re: Starter is dead I think (sieger)
sometimes if your starter is old, your starter contacts might be worn. These are very cheap to replace instead of a complete starter (couple bucks as opposed to 100+)... I would try that first. Make sure your battery terminals are clean and not corroded (sp?).
jgett002
Aug 3, 2016 02:00 PM
sd_ej1
16
Jan 24, 2009 06:21 PM
lilsol89
Jan 5, 2009 03:57 PM
IIXtremeHansen
24
Jun 11, 2007 10:28 AM
mingchi69
Jul 14, 2003 06:14 PM
