Low TPS Voltage???
Old Oct 7, 2002 | 10:20 AM
98R-1144's Avatar
Default Low TPS Voltage???
Been noticing that the throttle position on my VAFC never reaches 100% @ WOT when the engine is running (MAX % is often recorded from 96%-99%).
However, if the engine is off, the throttle reaches 100% @ WOT.
Then I noticed that my TPS voltage is:
0.435 (+/- 0.005) with the TB closed, engine off
4.385 (+/- 0.005) @ WOT, engine off
Is this too low? Could this be why the V-AFC never reads 100% throttle @ WOT when the engine is running? Does this mean this entire time, everytime I've been flooring it, it hasn't been going at WOT??
Old Oct 7, 2002 | 10:56 AM
FSTASNTZ's Avatar
Default Re: Low TPS Voltage??? (98R-1144)
Is your thorttle cable tight? Did you at any point adjust the TPS itself?
Jason
Old Oct 7, 2002 | 11:07 AM
98R-1144's Avatar
Default Re: Low TPS Voltage??? (FSTASNTZ)
Nope..never played with my TPS in any way
As for the throttle cable, it seems to be tight. If i tighten it up a bit to read 0.45-0.50 with the TB closed... would that work as well?
Would it be ~4.5V @ WOT then?
Old Oct 7, 2002 | 11:10 AM
577HondaPrelude's Avatar
typical voltage for the TP sensor is 0.45V at idle, and 4.5V at WOT. your not that far off... like FSTASNIZ said check for extra slack in the thorttle cable.
Old Oct 7, 2002 | 11:17 AM
98R-1144's Avatar
Default Re: Low TPS Voltage??? (57STS)
Yeah I'll double check that tonight...
Should only the cable be adjusted..or should the idle be adjusted as well to compensate?
Either way though, if the cable is adjusted, wouldn't it still reach the same 96-98% @ WOT since the butterfly still opens to the same max point?
Does reaching this 96-98% MAX affect anything? Am I missing out on a "true" WOT?
Old Oct 7, 2002 | 11:28 AM
CHEETAH's Avatar
you're still seeing WOT, however your TPS sensor is slightly off by +1.5 mV ... that will raise it sloser to both open and closed threshold. This won;t affect performance.
Greg
petrv
Sep 22, 2006 09:33 AM
DeDonDeRosa
Dec 2, 2005 04:27 AM
Mr. JDM-GSR
Sep 24, 2005 11:38 AM
smkngsr
Mar 22, 2005 10:40 PM
redlinegsr
Dec 5, 2002 12:56 PM
